Newbie with a problem - can't get bed to heat up at all sad smiley
Posted by MrCrispi
Re: Newbie with a problem - can't get bed to heat up at all sad smiley
January 16, 2014 09:33AM
RS stock number is 746-8208 website is rswww.com - thanks
January 16, 2014 10:05AM
The data sheet says this has a beta value of 3350–3399K, much lower than ours. Your bed will report a temperature higher than actual, by about 5-10C, I think.
Ian
RepRapPro tech support
January 16, 2014 10:06AM
The beta of that thermistor is significantly lower than the calculation assumes. I've attached a spreadsheet to calculate the error this will introduce.
open | download - Thermistor.ods (14 KB)
January 16, 2014 10:45AM
Excellent - thanks; much appreciated
January 16, 2014 03:30PM
Or you can buy this one from RS: 706-2780 its the same item as the one from Farnell.
Paul
RS Ormerod No 436
