Earthing - potential ground loop problem? January 14, 2014 10:55AM |
Re: Earthing - potential ground loop problem? January 14, 2014 11:59AM |
Re: Earthing - potential ground loop problem? January 14, 2014 04:23PM |
Re: Earthing - potential ground loop problem? January 14, 2014 07:27PM |
Re: Earthing - potential ground loop problem? January 15, 2014 05:02AM |
bobc
I must admit to being slightly puzzled, the solution to ground loops and all the other problems on USB is Ethernet... and it is there on the Duet already. Ethernet is isolated, so there are no ground loop issues, the protocols are designed to be robust and recover from errors, and is probably faster than USB, depending on type.
You can even get a telnet serial interface so it looks like a COM port on the PC, so no changes are required to pronterface, although a plain TCP socket interface would be straightforward.
