Swollen prints - any ideas?
Posted by dc42
January 15, 2014 12:12PM
I'm finding that all my prints come out slightly swollen. I've been trying to print the z-gear and z-driven gear, but the parts I print are too tight to fit on the motor spindle and bearing. If I drill/file them out so that they fit, then the teeth mesh too tightly and won't rotate. So my printed gears are swollen on the inside and the outside.
I've tried reducing the extrusion factor in slic3r, first to 0.95 and now to 0.90. This has helped somewhat, but not enough. I'm going to try reducing it even further. But why should this be necessary? I calibrated the steps/mm for the filament feed and it was spot on at 420. The filament I am using is not oversize, if anything it is nearer 1.70mm than the 1.75mm I set in slic3r.
So I have a couple of questions:
1. What is the tolerance on the diameter of the 0.5mm nozzle?
2. Are there any other factors that might be causing my prints to swell?
Re: Swollen prints - any ideas?
January 15, 2014 12:16PM
Hi dc42,
did you try to print the gears with lower speed, say 10mm/s? That works fine for me.
I usually slow down when I need high accuracy/ resolution.
Markus
XBee & electronics blog: [lookmanowire.blogspot.com]
January 15, 2014 12:34PM
Markus, do you reduce all the speeds to 10mm/s, or just some of them?
January 15, 2014 12:38PM
Hi dc42,
only some of them where I think they are important for finer structures like perimeter e.g.
Markus
January 15, 2014 12:41PM
dc42,
The Slic3r manual (or website, I forget which) recommends measuring the extrudate's width (extruded from up high and measured at a few points then using the average) to find a useful value to enter as the the nozzle size. They also suggest printing a single wall shell noting the expected thickness in the gcode then comparing to measured thickness, and using that ratio to set the extrusion factor (this last on top of the calibrations you've already done - if you have the extrusion factor set to say 0.90 and find the expected/actual width is 0.9, then you need to compound the two and set it to 0.81, or just set it to 1 before you run the test). You can quickly make a test shell by slicing a simple cube stl with no infill, no top layers, two or three bottom layers and a single perimeter (rather like the gearfail.gcode I uploaded recently) - the (newish) spiral vase slic3r option may be quicker .
to get more "accurate" prints, I find it helps to constrain the layer width - I set the default width to 0.5mm and it really does seem to help getting parts to fit.
Ray
January 15, 2014 12:58PM
As we are talking settings - any ideas how to get rid of those "blobs" in inner edges? Outer edges are ok...
Like so:
Markus
Sorry dc42 no hijacking intended!
Edited 1 time(s). Last edit at 01/15/2014 01:20PM by markbee.
January 15, 2014 01:17PM
markbee
As we are taking settings - any ideas how to get rid of those "blobs" in inner edges? Outer edges are ok...
My guess is that they are caused at the start or end of a non-print move that is made without retracting the filament. Make sure you have changed the setting to retract 4mm instead of the default of 1mm, and try a print after unticking the box that says "Only retract when crossing perimeters" in the "Print Settings" / "Infill" page of Slic3r.
Dave
(#106)
January 15, 2014 02:06PM
On top of Dave's spot on suggestions, you could also add "wipe on retract" which stops build ups on corners that always get a retraction.
Ray
January 15, 2014 02:13PM
I'd also like the option "wipe on saturdays" winking smiley
SCNR
Markus
January 16, 2014 04:32AM
Thx dmould and Ray,
I tested those settings but still get the same result. It's even like the printing errors also on other parts of the print almost always repeat at the same places, so it could be a software/ slicer or firmware issue?
The settings for the prints shown in the photo are changed between those prints (and some more) but the errors always stays the same. Settings changed: randomize starting point, retraction length, wipe on retraction, only retract when crossing perimeters - but to no avail.
A photo of the recurring errors regardless of the settings change:
Markus
January 16, 2014 04:41AM
one thing that seems to be happening is that the upper two circled features are on the same layer as the top or bottom of holes further along the print. if you look at the edge near the lower large hole (uncircled) you can see that the whole wall is offset a little, looking to the right of that hole, there's a line that also coincides with the top of a small hole just visible towards the rear of the print.
Maybe your head, or your table is moving a little when the head snags on these boundaries?
Ray
January 16, 2014 04:45AM
Markus, I can't see that "retract only on crossing perimeters" will make much difference because that only affects infill. The critical change for me was increasing retraction to 4mm. I've also increased the max filament speed.
What extruder temperature and which firmware version are you using? I think you may have the temperature a little high.
Edited 1 time(s). Last edit at 01/16/2014 04:45AM by dc42.
January 16, 2014 05:03AM
Hi Markus
It looks more like a Z axis movement problem to me, like those layers are not moving up enough, so it squashes out like the filling in a sandwich. Are you on the latest firmware?
The nodules on corners look like you need to increase retraction distance and/or speed.
Ian
RepRapPro tech support
Hi dc42,
I had retraction set to 4mm and speed to 30mm/s. Firmware was 058 but I had those errors with firmware versions before. Extruder temp is 200 for the first layer and 190 for the subsequent layer.
Markus
January 16, 2014 08:04AM
When I got slightly uneven layers I tracked it down to very occasional slipped steps in the Y axis. This happened more when the bed made small fast movements (e.g. during short non-printing moves) than when making large movements. There was no progressive movement because the machine seemed to miss steps in one direction just as often as it did in the other, so it averaged out over the whole print, but exhibited different effects on layers containing small movements than layers containing large movements - looking very similar to the effects your photos show, and layers containing holes etc. cause different moves to layers that do not. My first solution was to slow the speed to 20mm/s for all moves (printing and non-printing) and that seemed to work, but gave very long print times. Later I increased the motor current to 1000mA in the startup g file, and the problem appears to have disappeared, so now I can print at faster speeds again. In fact I should have been playing with the acceleration settings, because it is acceleration rather than speed that causes missed steps. My bed moves very easily and smoothly when the machine is switched off, and I've oiled the runner, so it's not a sticking bed - I think 800mA may be a little too low for the inertia of the bed, and 1000mA is well within the specs of the stepper motors.
Also, if the Y belt is a bit too loose there will be backlash, which I found causes a slight bulge on the edges of the print in the direction of Y movement, but the side of the bulge depends on the direction of travel that the layer was printed, so can change from layer to layer. I will definitely be trying the clothes peg trick to tension the Y belt as soon as my machine is running again (thanks to whoever posted that video).
Or maybe I mis-diagnosed the fault and am spouting rubbish - although what I did appears to have worked!
Dave
(#106)
djb
January 16, 2014 09:18AM
dmould
Dave
(#106)
That was me smiling smiley - I was getting offsets in layers along the Y axis before using it which I presumed was from the direction changes as I could see the belt flexing.
Daryl
RS Ormerod #299
