Re: Slack! January 16, 2014 06:54PM |
Re: Slack! January 16, 2014 07:44PM |
Re: Slack! January 17, 2014 04:38AM |
droftarts
Put a cable tie around the two belts, on the left hand side of the rib, and push it up to the rib, then tighten. That stops it.
Ian
RepRapPro tech support
Re: Slack! January 18, 2014 06:24AM |
Re: Slack! January 18, 2014 06:39AM |
Re: Slack! January 18, 2014 07:13AM |
Re: Slack! January 18, 2014 07:22AM |
Re: Slack! January 18, 2014 07:37AM |
rayhicks
Nice idea
I printed and fitted Matt's solution yesterday - which works fine (thanks Matt), but doing your mod would have saved me an hour or two and it's probably much easier to tension than on Matt's the belt was a very tight fit the way I printed it . One advantage of Matt's is that the two clamps butt up to the rear support and stop the rib swaying (adding to the rigidity of the table and preventing the little wiggle around Z I'd been having).
Cheers
Ray
Re: Slack! : SOLVED January 18, 2014 11:48AM |
