hot end temperature (fw 0.57a) January 17, 2014 08:29AM |
Tr Tm
-2.42 20
25.7 33
51.2 55
72.4 73
99.7 100
150 144
197.3 188
221.9 208
243.1 225
269.3 248
Re: hot end temperature (fw 0.57a) January 17, 2014 09:28AM |
Re: hot end temperature (fw 0.57a) January 17, 2014 09:55AM |
- curve fitting my data from 100°C upwards in excel gives me an intercept of 13.45 and a slope of 0.87 with a very good r^2 (0.9995) - perhaps a gcode or two could be given up to (optionally) calibrating the response on a particular system using such a fit? Though calbration would need to be done for each thermistor and would require the user to have a means of reliable temperature measurement, so may not be worth the effort (which may be better spent on designing a thermocouple interface to replace the thermistor).
Re: hot end temperature (fw 0.57a) January 17, 2014 10:09AM |
Re: hot end temperature (fw 0.57a) January 17, 2014 10:22AM |
Re: hot end temperature (fw 0.57a) January 17, 2014 10:44AM |
Re: hot end temperature (fw 0.57a) January 17, 2014 11:04AM |
dc42
Hi dmould,
Yes the thermistor reading code has changed. The old code under-reported the extruder temp at low temperatures and over-read it at high temperatures. However, the code for reading the IR sensor has not changed at all. Perhaps your sensor has shifted position, or the connector is coming loose? The screw holes in it allow for quite a lot of movement.
Re: hot end temperature (fw 0.57a) January 17, 2014 12:26PM |
