Firmware update problem January 17, 2014 09:02PM |
Re: Firmware update problem January 17, 2014 09:16PM |
Re: Firmware update problem January 17, 2014 09:30PM |
Re: Firmware update problem January 17, 2014 10:49PM |
Re: Firmware update problem January 18, 2014 12:03AM |
Re: Firmware update problem January 18, 2014 01:32AM |
Re: Firmware update problem January 18, 2014 01:50AM |
Re: Firmware update problem January 18, 2014 02:21AM |
Re: Firmware update problem January 18, 2014 02:49AM |
Re: Firmware update problem January 18, 2014 04:11AM |
Re: Firmware update problem January 18, 2014 04:14AM |
Re: Firmware update problem January 18, 2014 04:21AM |
Re: Firmware update problem January 18, 2014 05:12AM |
Re: Firmware update problem January 18, 2014 05:20AM |
ls /dev/cu.*It should respond with
/dev/cu.Bluetooth-Incoming-Port /dev/cu.usbmodem1451 /dev/cu.Bluetooth-ModemThis lists the ports that the Mac can see (all ports are listed in /dev/), that start with 'cu.'. You need the one that starts 'usbmodem....'. Use this in the bossac command.
Re: Firmware update problem January 18, 2014 05:38AM |
Re: Firmware update problem January 18, 2014 05:46AM |
Re: Firmware update problem January 18, 2014 05:48AM |
Re: Firmware update problem January 18, 2014 06:38AM |
Re: Firmware update problem January 18, 2014 06:47AM |
Re: Firmware update problem January 18, 2014 06:49AM |
[localhost:/applications] bill%Whereas mine is just
Ians-MacBook-Pro:~ Ian$So you probably DO need to put it in as
/dev/cu.usbmodem24680241
Re: Firmware update problem January 18, 2014 07:01AM |
Re: Firmware update problem January 18, 2014 07:06AM |
Re: Firmware update problem January 18, 2014 03:59PM |
Re: Firmware update problem January 18, 2014 04:32PM |
Re: Firmware update problem January 18, 2014 05:01PM |
Re: Firmware update problem January 18, 2014 05:52PM |
Re: Firmware update problem January 18, 2014 07:02PM |
Re: Firmware update problem January 18, 2014 07:14PM |
Re: Firmware update problem January 18, 2014 07:23PM |
Re: Firmware update problem January 18, 2014 08:06PM |
