Re: Firmware update problem January 18, 2014 08:28PM |
Re: Firmware update problem January 18, 2014 08:35PM |
Re: Firmware update problem January 18, 2014 08:55PM |
Re: Firmware update problem January 19, 2014 01:36AM |
Re: Firmware update problem January 19, 2014 02:12AM |
Re: Firmware update problem January 19, 2014 06:35AM |
Re: Firmware update problem January 19, 2014 03:50PM |
Re: Firmware update problem January 19, 2014 04:48PM |
Re: Firmware update problem January 19, 2014 08:13PM |
Re: Firmware update problem January 21, 2014 01:30AM |
Re: Firmware update problem January 21, 2014 02:16AM |
ozeng
There are 5 soldered connections on the duet board apart from the grounding/support ones (see attached pic of my 1st board) - I don't have the gear or skills to resolder them.
Re: Firmware update problem January 21, 2014 04:28AM |
Re: Firmware update problem January 21, 2014 05:15AM |
Re: Firmware update problem January 21, 2014 06:24AM |
Re: Firmware update problem January 28, 2014 12:51AM |
Re: Firmware update problem January 28, 2014 05:56AM |
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/bossac -e -w -v -b RepRapFirmware-XXX-DD-MM-YYYY.bin -R
Ians-MacBook-Pro:tools Ian$ ./bossac -h Usage: bossac [OPTION...] [FILE] Basic Open Source SAM-BA Application (BOSSA) Version 1.3a Flash programmer for Atmel SAM devices. Copyright (c) 2011-2012 ShumaTech (http://www.shumatech.com) Examples: bossac -e -w -v -b image.bin # Erase flash, write flash with image.bin, # verify the write, and set boot from flash bossac -r0x10000 image.bin # Read 64KB from flash and store in image.bin Options: -e, --erase erase the entire flash -w, --write write FILE to the flash; accelerated when combined with erase option -r, --read[=SIZE] read SIZE from flash and store in FILE; read entire flash if SIZE not specified -v, --verify verify FILE matches flash contents -p, --port=PORT use serial PORT to communicate to device; default behavior is to auto-scan all serial ports -b, --boot[=BOOL] boot from ROM if BOOL is 0; boot from FLASH if BOOL is 1 [default]; option is ignored on unsupported devices -c, --bod[=BOOL] no brownout detection if BOOL is 0; brownout detection is on if BOOL is 1 [default] -t, --bor[=BOOL] no brownout reset if BOOL is 0; brownout reset is on if BOOL is 1 [default] -l, --lock[=REGION] lock the flash REGION as a comma-separated list; lock all if not given [default] -u, --unlock[=REGION] unlock the flash REGION as a comma-separated list; unlock all if not given [default] -s, --security set the flash security flag -i, --info display device information -d, --debug print debug messages -h, --help display this help text -U, --force_usb_port=true/false override USB port autodetection -R, --reset reset CPU (if supported)
Re: Firmware update problem January 30, 2014 08:49PM |
Re: Firmware update problem January 30, 2014 09:03PM |
ozeng
Basically the erase and reset buttons delete the usb port and so bossac can't talk to the duet
Re: Firmware update problem January 30, 2014 09:14PM |
Re: Firmware update problem January 31, 2014 04:06AM |
ozeng
Thanks dc42,
does that mean I can fabricate an address from the one that used to work, namely: /dev/cu.usbmodemfa131 ?
Re: Firmware update problem January 31, 2014 04:18AM |
Re: Firmware update problem January 31, 2014 05:49PM |
Re: Firmware update problem January 31, 2014 06:10PM |
Re: Firmware update problem January 31, 2014 08:07PM |
Re: Firmware update problem February 01, 2014 04:15AM |
Re: Firmware update problem February 01, 2014 06:45PM |
Re: Firmware update problem February 04, 2014 03:26PM |
Re: Firmware update problem February 04, 2014 04:06PM |
Re: Firmware update problem February 04, 2014 04:39PM |
Re: Firmware update problem February 04, 2014 05:12PM |
