Hot End Thermister Problem
Posted by ntroufan
January 17, 2014 11:48PM
The temperature on the hot end is reading incorrectly. I get a reading of -2.7 where it should be room temperature.
I have checked the wiring and everything seems to be fine. I've unplugged the thermister and immediately got an error and a -275 degree reading. I also put my hands on it and the temperature went up to 9 degrees... So it seems that it is working. Any ideas what might be wrong?
Re: Hot End Thermister Problem
January 18, 2014 12:17AM
I have the same problem too. I suspect that the thermistor can only work accurately when it heat up to higher temperature, at room temperature it will operate at unlinear region. Mine shows 12 degree, and my actual room temperature is 27 degree. I believe it's normal.
January 18, 2014 12:27AM
Have you been able to print successfully without the hotend overheating or underheating?
January 18, 2014 02:25AM
Mine not printing yet , still stuck at commissioning stage. ( Just received the Ormerod 3 days ago) I did check with temperature using industrial thermometer. hotend temperature seems quite accurate .
January 18, 2014 03:13AM
My hot end thermistor also reports incorrectly at room temp, often between -28° and +6°.
It does however print fine, I usually print with the hot end at about 185°c
Matt
Limited Edition Red RS Ormerod 1 #144 of 200 - RRP 1.09fw
iamburnys Ormerod Upgrades Github
Follow me on ThingiVerse My Designs
January 18, 2014 04:17AM
The cause of a wrong thermistor reading is most probably with the connector. I just put the thermistor directly to the duet using jumper wires and it reads the room temperature just fine. So try improving the connection or use a separate cable for the thermistor.
January 18, 2014 05:00AM
I think voltage drop along the cable, and added resistance of connectors, effects the reading at low temperature, when the resistance of the thermistor is at it's highest. Especially as we're using 3.3V. Check connections are good, that pins are not pushed out of the crimp housings.
Ian
RepRapPro tech support
January 18, 2014 05:57AM
Also, update the firmware on the Duet board if you have not already done so. The current version is 0.57a. Firmware earlier than 0.53 gave less accurate temperature readings.
January 18, 2014 06:56AM
My thermistor also underreads at room temp, which led me to do some testing yesterday [forums.reprap.org] dmould did similar tests and got results that better accorded between his thermistor and thermocouple, which I presumed to be due to different thermocouple placement -I'll try cleaning the thermistor legs and plugging it in direct (as adsoftware reports above) to the duet and see if high contact resistance is the cause of my offset too! [edit you can see in my table that my low end temperature was way off around room temp, it actually drops to -20 odd at 15°C, but I'd put that down to quantization error and I'm not really worried about accuracy that far from working temp]
Ray
Edited 1 time(s). Last edit at 01/18/2014 07:00AM by rayhicks.
January 18, 2014 07:06AM
The resistance of the thermistor is 100K at 25C, so it's most unlikely that you would get a high enough contact resistance to affect the reading. OTOH I had my reading drop to -273 a few times, which indicates open circuit. I had to tighten up the receptacles in the 6-way socket to cure this.
