Help Please (Trying to Commission the Printer) January 18, 2014 06:07PM |
Re: Help Please (Trying to Commission the Printer) January 18, 2014 06:12PM |
Re: Help Please (Trying to Commission the Printer) January 18, 2014 07:06PM |
Re: Help Please (Trying to Commission the Printer) January 18, 2014 07:22PM |
Re: Help Please (Trying to Commission the Printer) January 18, 2014 07:30PM |
KimBrown
LoL then the fun started trying to find the thermistor fault..... Not easy working here in my cabin with just a digital multimeter with probes the size of fingers... Then I remembered I had some safety pins in my bag and used them as probes to get inside the plug.
Turned out to be the connector on top of the Hot Head... A splayed socket... fixed with a gentle shove with a safety pin....
Not sure I like that connector... Me thinks it's going to get binned and something a bit more robust put in it's place..
Re: Help Please (Trying to Commission the Printer) January 18, 2014 07:36PM |
Re: Help Please (Trying to Commission the Printer) January 18, 2014 10:05PM |
Re: Help Please (Trying to Commission the Printer) January 19, 2014 12:05AM |
KimBrown
It turned out the SD card that came with the kit was faulty (I'll try formatting it tomorrow and see if that breaths life in to it).
Re: Help Please (Trying to Commission the Printer) January 19, 2014 01:22AM |
KimBrown
Maybe someone could add a diagram to the instructions saying which is Positive and Negative for the different
movements (ok it's late, I'm human, and I can't spell axi at this time of night...lol)
Kim..
Re: Help Please (Trying to Commission the Printer) January 19, 2014 03:31AM |
KimBrown
Right well my question is about the Y axis...
Positive Y makes the table come towards the motor, otherwise it follows the diagram on the Printer Interface.
Re: Help Please (Trying to Commission the Printer) January 19, 2014 06:55AM |
Re: Help Please (Trying to Commission the Printer) January 19, 2014 09:25AM |
Re: Help Please (Trying to Commission the Printer) January 19, 2014 09:27AM |
Re: Help Please (Trying to Commission the Printer) January 19, 2014 09:31AM |
KimBrown
Would you believe it... I sent the message, and then a few moments later it springs in to life.
Sorry to trouble you guys...
Re: Help Please (Trying to Commission the Printer) January 19, 2014 12:14PM |
Re: Help Please (Trying to Commission the Printer) January 19, 2014 12:17PM |
Re: Help Please (Trying to Commission the Printer) January 19, 2014 03:47PM |
Dave_Longdown
>Even if the supplied SD card seem to work I would snap it in half and burn it
That is a very, very good idea. However, try this: Get a good microSD card, and then use some super glue and Kapton tape to attach it to the supplied (bad) SD card so that it is now twice as long. Why? Because it makes it much easier to insert and remove the good SD card from the Ormerod! Obviously mark the 'bad' SD card as such with some nail varnish or permanent marker pen...
Re: Help Please (Trying to Commission the Printer) January 21, 2014 05:17AM |
Re: Help Please (Trying to Commission the Printer) January 21, 2014 05:27AM |
Re: Help Please (Trying to Commission the Printer) January 21, 2014 05:28AM |
Re: Help Please (Trying to Commission the Printer) January 21, 2014 09:52AM |
reprappro
Yes. Change the gateway address to 192.168.0.1 and the ip address of the printer to 192.168.0.## where ## is a number that isn't another device's ip address on the network.
Ian
RepRapPro tech support
Re: Help Please (Trying to Commission the Printer) January 21, 2014 11:30AM |
