homemade ormerod? January 19, 2014 09:35PM |
Re: homemade ormerod? January 22, 2014 04:37PM |
Re: homemade ormerod? January 22, 2014 04:46PM |
Re: homemade ormerod? January 22, 2014 05:11PM |
Re: homemade ormerod? January 22, 2014 06:36PM |
Re: homemade ormerod? January 22, 2014 07:12PM |
Re: homemade ormerod? January 22, 2014 08:03PM |
rayhicks
... snip ... you'll need to get an optical Z probe from RRP though if you want to home Z and X (it checks reflected light from the bed, and from a piece of plastic at the right height near the home position of X rather than using two microswitches).
Ray
Re: homemade ormerod? January 22, 2014 08:26PM |
Re: homemade ormerod? January 22, 2014 08:46PM |
Re: homemade ormerod? January 22, 2014 08:56PM |
I can hack a switch and a resistor, and I could enter a gcode (if the firmware would recognise one to enable the right pin), but just now I'm not able to compile my own firmware and won't be for some time - it would seem reasonable that you (or maybe t3dp3d) do provide support in firmware for gcodes to enable more functionality from the duet, but I know your to-do list is still not short enough for random feature requests to hit the top|
Re: homemade ormerod? January 23, 2014 05:20AM |
Re: homemade ormerod? January 23, 2014 05:44AM |
Re: homemade ormerod? January 23, 2014 05:51AM |
Re: homemade ormerod? January 23, 2014 07:59AM |
Re: homemade ormerod? January 28, 2014 03:58AM |
Re: homemade ormerod? February 05, 2014 11:00AM |
Re: homemade ormerod? February 05, 2014 11:11AM |
Re: homemade ormerod? February 05, 2014 12:25PM |
Re: homemade ormerod? February 05, 2014 01:19PM |
Re: homemade ormerod? February 07, 2014 08:00AM |
Re: homemade ormerod? February 07, 2014 08:32AM |
Re: homemade ormerod? February 07, 2014 08:38AM |
Re: homemade ormerod? February 07, 2014 09:01AM |
Re: homemade ormerod? February 07, 2014 10:15AM |
eaj29
...Where can I get all the acrylic parts cut out? Ideally, I would replace them by aluminium parts, does anyone know a service that ships to/is located in Germany?
--Eric
Re: homemade ormerod? March 09, 2014 08:20AM |
dc42
Regarding the IR sensor, I strongly recommend that you go for a modulated one. I expect that RRP will be selling these within a few weeks. I am also considering making a modulated sensor pcb that fits on the hot end, and that integrates the hot end connector and a light to illuminate the work. See [forums.reprap.org].
Re: homemade ormerod? March 09, 2014 08:38AM |
karabas
Will it work with semitransparent bed - sanded glass or antiblink relief glass ?
Re: homemade ormerod? March 09, 2014 12:55PM |
dc42
karabas
Sorry, I don't know what antiblink relief glass is, and neither does Google. Do you mean can you use light reflected off a particular type of glass, without using white tape? I just tried reflecting off a piece of frosted glass, and the highest reading I could get was about 80. However, Kim reported good results using red glass. I'm not sure whether he was using the reflection from the glass, or from the aluminium bed under the glass.
I am now manufacturing modulated IR (and ultrasonic) sensors, see [forums.reprap.org].
Re: homemade ormerod? March 09, 2014 04:23PM |
Re: homemade ormerod? March 09, 2014 05:47PM |
karabas
I never cool the bed between prints just replace glass. That is why I need any reliable Z sensor.
Re: homemade ormerod? March 09, 2014 05:56PM |
