Slic3r settings for Omerod
Posted by DennisCowdery
January 20, 2014 07:30AM
I have finally got RS343 up and running!
I can print out the sample G files (coathook etc)
When I use Slic3r to convert STL to G codes the result is all wrong - steps huge, no feed.
Pronterface shows this step coarseness.
QUESTION-
Does anyone have a good set of defaults to load into Slic3r for Omerod??
Thanks
Dennis
Re: Slic3r settings for Omerod
January 20, 2014 08:12AM
Hi Dennis,
The commissioning instructions covers your question:
6. The Ormerod files – profiles for Slic3r, and all the files you need to print another Ormerod
Edited 1 time(s). Last edit at 01/20/2014 08:13AM by 3D-ES.
RS-Online Ormerod #263, Kossel mini with Minitronics, Prusa i3 MK2
January 20, 2014 09:58AM
Hi 3D-ES
The commmisioning link does indeed tell yow you how to get the software. It is installed and runs the test pieces OK.
However when I load a STL file then the output winds up with a 'lay spacing' of 5mm, and no plastic feed.
It is this I am trying to fix.
Baffled and greatful for help.
Dennis
January 20, 2014 10:42AM
I *think* I imported the configuration settings like this:
- Start Slic3r
- Open the tab "Print Settings"
- Click "File->Load config"
- Select the file "Slic3r-settings\ print \Ormerod-0.5.ini"
- Open the tab "Filament Settings"
- Select the file "Slic3r-settings\ filament \Ormerod-0.5.ini"
- Open the tab "Printer Settings"
- Select the file "Slic3r-settings\ printer \Ormerod-0.5.ini"
Since I am away from my printer, this answer might be wrong...
January 20, 2014 11:40AM
Instructions for installing the profiles are on the Printing page, here: [www.reprappro.com]
Ian
RepRapPro tech support
January 22, 2014 07:20AM
DennisCowdery
Hi 3D-ES
Dennis
Sorry if I keep repeating myself, but reprap slicer settings dating back to December are incorrect. Unless you downloaded reprap settings after 07/01/2014 your printer will be using absolute rather than relative E distances and nothing will come out of the extruder.
In slic3r, under printer settings, general, tick the box Use relative E distance, slice your part and watch it print!
Edited 1 time(s). Last edit at 01/22/2014 07:20AM by arnaud31.
January 22, 2014 11:32AM
SNAP!
Looks like we posted similar threads at the same time.
Look at my thread near the bottom... DC42 posted the Slic3r ini files there... I'm getting perfect results now.
My similar thread
Kim
January 22, 2014 05:08PM
I have to ask, maybe dumb question, is the Slic3r that runs from pronterface the same thing as the latest windows GUI version? I am using the windows GUI version without issues but had no success with the pronterface installed version. The only problem I have at this stage is that my print jobs all develop blobs on sharp corners for example a box corner... probably settings as the default g-code examples for the Ormerod print perfectly.
Dieter
Ormerod #257
