Re: Slic3r Help Please January 23, 2014 09:01AM |
Re: Slic3r Help Please January 23, 2014 09:23AM |
Re: Slic3r Help Please January 23, 2014 09:26AM |
Re: Slic3r Help Please January 23, 2014 09:42AM |
dmould
PaulHam
dmould
My first gear had hollow teeth also. Fixed by changing the "infill" setting to 0.6
Is that the infill density?
Sorry, yes, that's the one I changed. i think the default was 0.4?
Dave
(#106)
Re: Slic3r Help Please January 23, 2014 03:39PM |
Re: Slic3r Help Please January 23, 2014 03:48PM |
Re: Slic3r Help Please January 23, 2014 04:29PM |
Re: Slic3r Help Please January 23, 2014 04:40PM |
Thats the problem i think i had last night. but today i changed the settings and clicked save next to the drop down. then sliced.Quote
KimBrown
I'd import the new ini file, save, then exit Slic3r, then re-open it to be on the safe side.
Your trials with the other settings.... Did you save the ini files before you sliced the stl?
I think that's were I was going wrong... Importing, thinking they were in use, when I hadn't saved them, and they weren't being used for some reason.
Kim..
Re: Slic3r Help Please January 23, 2014 05:37PM |
Re: Slic3r Help Please January 23, 2014 05:41PM |
Re: Slic3r Help Please January 23, 2014 05:43PM |
Re: Slic3r Help Please January 23, 2014 05:50PM |
Re: Slic3r Help Please January 23, 2014 06:31PM |
Re: Slic3r Help Please January 23, 2014 06:44PM |
Re: Slic3r Help Please January 23, 2014 07:27PM |
Re: Slic3r Help Please January 24, 2014 03:28AM |
Re: Slic3r Help Please January 24, 2014 08:15AM |
Re: Slic3r Help Please January 24, 2014 10:02AM |
dc42
My settings files were made for slic3r 1.0 RC2. If you load the standard Ormerod settings files in any slic3r 1.0, it warns you that the settings files are old and should be re-made from scratch. So there is some incompatibility between settings files for 1.0 and pre-1.0 slic3r, and I guess the settings files I provided may not work well with slic3r 0.9.9.
Re: Slic3r Help Please January 25, 2014 11:01PM |
dc42
Re: Slic3r Help Please January 29, 2014 09:53AM |
Re: Slic3r Help Please January 29, 2014 10:29AM |
GregL
@dc42
I have picked up your ini files from 22nd jan
'Here are my standard slic3r files. The 429b one is filament, 2kb one is print, 930b is printer.'
I updated the simple.ini and the slic3r.ini with the RepRap ones as the instructions suggested
It is not clear to me which of the Slic3r files your new ones replace.
Help!
Greg
Edit to add - I think I have found the locations to post them. Do I delete the existing ones there?
eg Simple Mode.ini with your Ormerod....ini in the printer folder
Re: Slic3r Help Please February 01, 2014 07:47AM |
Re: Slic3r Help Please February 01, 2014 08:01AM |
Re: Slic3r Help Please February 02, 2014 08:27AM |
