Pronterface & Firmware Wish List January 22, 2014 11:06PM |
Re: Pronterface & Firmware Wish List January 22, 2014 11:46PM |
Re: Pronterface & Firmware Wish List January 23, 2014 02:54AM |
Re: Pronterface & Firmware Wish List January 23, 2014 03:39AM |
Re: Pronterface & Firmware Wish List January 23, 2014 04:48AM |
dc42
I'm thinking of adding a Pause button on top of the Duet enclosure. This would immediately stop the print, raise the head 10mm, and turn off the heaters. Then ignore incoming commands until some specific command is received (e.g. a home command, or M115) that indicates the user is back in control.
Re: Pronterface & Firmware Wish List January 23, 2014 09:06PM |
Re: Pronterface & Firmware Wish List January 24, 2014 03:42AM |
Re: Pronterface & Firmware Wish List January 24, 2014 04:01AM |
Re: Pronterface & Firmware Wish List January 24, 2014 04:30AM |
Download the following, and install in this order: [python.org] [pypi.python.org] [downloads.sourceforge.net] [pypi.python.org] [pyglet.googlecode.com] For the last one, you will need to unpack it, open a command terminal, go into the the directory you unpacked it in and run: python setup.py install
If I click on Extrude (25mm) it's jerky....
I tried to send a gcode file over USB..... waited and waited for it to finish uploading, then did a second file.
Ran the print, and it did next to nothing. Powered down, unplugged USB, SD card put in Laptop...
One zero length file, and one file that was half length..... and yet the files seemed to go across intact.
Firmware 57... Just had my first printer freeze tonight.....
I don't like that once printing starts, I can't instantly pause it, or reset it.
On the reset subject.... Does that clear Z0 settings?
I appreciate that the machine is in Beta, but I don't think it should have been put on sale without it basically working properly.
Re: Pronterface & Firmware Wish List January 24, 2014 04:56AM |
I use this version, but agree it's not an easy route for those who like a simple install.Quote
2. The harder install-multiple-parts-yourself release that contains the file printcore.py.
Re: Pronterface & Firmware Wish List January 24, 2014 05:12AM |
Re: Pronterface & Firmware Wish List January 24, 2014 06:13AM |
Re: Pronterface & Firmware Wish List January 24, 2014 06:23AM |
Re: Pronterface & Firmware Wish List January 24, 2014 08:28AM |
Re: Pronterface & Firmware Wish List January 24, 2014 08:37AM |
KimBrown
Thank you 3D, yes I had set 'wipe on retract' for that print... I've turned it off now, so that will be the reason for the freeze.
Re: Pronterface & Firmware Wish List January 24, 2014 09:12AM |
Re: Pronterface & Firmware Wish List January 24, 2014 09:23AM |
Re: Pronterface & Firmware Wish List January 24, 2014 06:12PM |
