10mm Deep fan January 23, 2014 09:45AM |
Re: 10mm Deep fan January 23, 2014 10:41AM |
Mickyblueeyes
I tried to add a deflector at the input end but this makes the fan a lot noisier so I need to try a few different designs to cure this, the backwash doesn't seem as bad as the original fan but I cant measure it.
Re: 10mm Deep fan January 23, 2014 11:39AM |
Re: 10mm Deep fan January 23, 2014 11:43AM |
Mickyblueeyes
Hi dc42 that was along the lines I was thinking as it was your modified deflector I chose, unfortunately having spent hours modifying it I now realise the new fan has 9 blades, I modified it to take the screws at the bottom but as with anything I do on Sketchup I spent more time repairing the file because of its poor stl import routine.
Maybe I need to go back and modify the original as I have a lot more depth to play with.
