Unable to update firmware January 24, 2014 04:10AM |
Re: Unable to update firmware January 24, 2014 04:40AM |
Re: Unable to update firmware January 24, 2014 04:43AM |
support@support-Desktop:~/arduino-1.5.5/hardware/tools$ ./bossac -h Usage: bossac [OPTION...] [FILE] Basic Open Source SAM-BA Application (BOSSA) Version 1.3a Flash programmer for Atmel SAM devices. Copyright (c) 2011-2012 ShumaTech (http://www.shumatech.com) Examples: bossac -e -w -v -b image.bin # Erase flash, write flash with image.bin, # verify the write, and set boot from flash bossac -r0x10000 image.bin # Read 64KB from flash and store in image.bin Options: -e, --erase erase the entire flash -w, --write write FILE to the flash; accelerated when combined with erase option -r, --read[=SIZE] read SIZE from flash and store in FILE; read entire flash if SIZE not specified -v, --verify verify FILE matches flash contents -p, --port=PORT use serial PORT to communicate to device; default behavior is to auto-scan all serial ports -b, --boot[=BOOL] boot from ROM if BOOL is 0; boot from FLASH if BOOL is 1 [default]; option is ignored on unsupported devices -c, --bod[=BOOL] no brownout detection if BOOL is 0; brownout detection is on if BOOL is 1 [default] -t, --bor[=BOOL] no brownout reset if BOOL is 0; brownout reset is on if BOOL is 1 [default] -l, --lock[=REGION] lock the flash REGION as a comma-separated list; lock all if not given [default] -u, --unlock[=REGION] unlock the flash REGION as a comma-separated list; unlock all if not given [default] -s, --security set the flash security flag -i, --info display device information -d, --debug print debug messages -h, --help display this help text -U, --force_usb_port=true/false override USB port autodetection -R, --reset reset CPU (if supported) Report bugs to support@support-Desktop:~/arduino-1.5.5/hardware/tools$
Re: Unable to update firmware January 24, 2014 04:47AM |
Re: Unable to update firmware January 24, 2014 05:09AM |
Re: Unable to update firmware January 24, 2014 05:15AM |
Re: Unable to update firmware January 24, 2014 05:17AM |
Re: Unable to update firmware January 24, 2014 06:02AM |
bossac --port=COM6 -U true -e ... bossac -p COM6 -U true -e ...
bossac -port=COM6 -U true -e ... ("No device found on ort=COM6") bossac --port=COM6 -U -e ... (no 'true' following -U)
bossac -pCOM6 -U true -e... bossac --p COM6 -U true -e ... bossac --pCOM6 -U true -e ...
Re: Unable to update firmware January 27, 2014 02:14PM |
Jan
Another thing, that is quite important is the use of the Bossac tool in order to upgrade the firmware on the controller board. In your documentation online, you write this COMMAND line:
"bossac --port=COM4 -U true -e -w -v -b RepRapFirmware-XXX-DD-MM-YYYY.bin -R"
On my WIN XP-PRO computer I get a constant error message "USB PORT ERROR" and I checked the documentation on Bossa´s website and you can omit the "--port=COMx -U" suffix. In that case the upgrader finds the correct USB port itself and then the upgrade will work perfect.
That means the command line should look like this:
"bossac -e -w -v -b RepRapFirmware-XXX-DD-MM-YYYY.bin -R"
Re: Unable to update firmware January 27, 2014 03:43PM |
Re: Unable to update firmware January 29, 2014 12:43PM |
Re: Unable to update firmware January 29, 2014 01:06PM |
Tommy1
Hi people,
I just used the above "bossac --port=COMx -U true -e -w -v -b RepRapFirmware-XXX-DD-MM-YYYY.bin -R" which I hope has worked for me.
I got a message saying:-
"Erase flash
No such file or directory"
Tom
Re: Unable to update firmware January 29, 2014 02:11PM |
Re: Unable to update firmware April 05, 2015 02:51PM |
Re: Unable to update firmware April 05, 2015 03:05PM |
Re: Unable to update firmware April 05, 2015 03:06PM |
Re: Unable to update firmware April 07, 2015 08:52AM |
ormerod168
vonTugboat
Did Arduino stop including Bossa with it's downloadables? Because I downloaded the installer and the zip and neither gave me Bossa...
Attached the version that works for me
Erik
Marc van Beelen
I downloaded the Arduino software as zip file and indeed an other bossac version was downloaded. That's where the main problem started since there appeared to be a version difference in bossac.exe (212kB in stead of 805 kB...)
Re: Unable to update firmware April 07, 2015 09:51AM |
Re: Unable to update firmware April 07, 2015 10:56AM |
dmould
The attached works for me.
Re: Unable to update firmware April 07, 2015 03:12PM |
Re: Unable to update firmware April 07, 2015 05:42PM |
Re: Unable to update firmware April 08, 2015 06:30AM |
Re: Unable to update firmware April 08, 2015 02:46PM |
Re: Unable to update firmware April 09, 2015 06:44AM |
Re: Unable to update firmware April 12, 2015 03:15PM |
Re: Unable to update firmware May 03, 2015 08:34AM |
Re: Unable to update firmware May 14, 2015 05:20PM |
Re: Unable to update firmware May 14, 2015 05:59PM |
Re: Unable to update firmware May 14, 2015 07:23PM |
Re: Unable to update firmware May 15, 2015 07:51AM |
