Unable to update firmware
Posted by Marc van Beelen
Re: Unable to update firmware
May 15, 2015 08:05AM
dmould
Another possible way to go would be to modify the firmware so that it looks for a firmware update file on the SD card. During initialisation, if it finds a firmware update file on the SD card that is a different version to the one installed, it updates its firmware from the file on the SD card. So long as all new Duets sold contain firmware with such a feature, uses will be able to update their firmware simply by copying the firmware update file onto the SD card and power-cycling the Duet.
That's how firmware updating is normally done on the Smoothieboard.
May 15, 2015 08:43AM
Hi Dave
Yes, we've considered this. The main problem is that you effectively need two firmwares. The initial one (or extended bootloader) that runs at startup, that can access the SD card (or network) and compare the installed firmware to the firmware on the SD card (or online), and which can overwrite the flash memory (without overwriting itself), tell you what it's doing (by the serial console) then exit memory cleanly before loading the actual firmware! The Duet doesn't have a lot of memory (100k), but at least should have enough flash memory to hold, effectively, two firmwares.
It's all do-able, probably, we just haven't had the skills and time available to implement this (or something like it).
Ian
RepRapPro tech support
May 15, 2015 09:21AM
dc42
I think Smoothieboard uses mBed, and that's quite a standard way of updating? It helps to have the in-house ARM devs behind you!
Ian
May 15, 2015 10:40AM
droftarts
Hi Dave
Ian
The way I do it for my products is to have a routine somewhere in the normal initialisation that looks to see whether a valid firmware update file exists and if so whether an update should be performed (firmware in file is different to firmware installed). If so, the actual Flash updating routine is copied to RAM, and the program then jumps to that RAM location. With instructions now being fetched from RAM, the whole Flash can be erased and the new firmware written, after which a software reset is carried out. As normal processing is suspended during firmware updating, it can re-initialise and use all of the available RAM if required (the update routine is written as a standalone program). A routine to erase the flash, read from SD card and write to Flash should not take more than a kB or so, though in your case you would probably need to do a walk through the SD card file system before you call the programming routine and make a RAM table of the SD card sectors to read to get the file data so that the programming routine running in RAM does not have to call any FAT32 routines but can pull data from the SD card directly by the pre-computed sector addresses. The flash programming routine I use (the part that you would need to run in RAM) takes up less than 100 bytes.
Dave
May 15, 2015 10:47AM
Dave - neat! Thanks for the ideas!
Ian
May 16, 2015 04:03AM
Hi Guys,
I am using a 32 bit Mac with OSX 10.6.8 and have Arduino 1.0.6 installed.
I have drilled down the folder structure but can see no sign of bossac. In the /hardware/tools directory there is only another folder called avr.
I have read further up about using Board Manager to add bossac, but can not see this in any of the menus on my set-up.
Any advice much appreciated.
Ralph
May 16, 2015 05:41AM
I can confirm that Bossa the gui version does NOT work with Mac computers, it never locates the port.
Brian
May 16, 2015 12:21PM
Europa
Brian
On the Arduino forum, I found a link to here [nw2s.net] for a Mavericks-only version of Bossac that is supposed to work with the Arduino Due
Edited 2 time(s). Last edit at 05/17/2015 03:28PM by dc42.
May 17, 2015 12:02PM
rjmusto
Hi Guys,
Ralph
You're using Arduino IDE 1.0.6? This version pre-dates the Arduino Due, so does not have support for ARM-based Arduino boards, only the old AVR boards. Use version 1.6.1, as per the instructions: [reprappro.com]
Then bossac is where the firmware update instructions says it is: [reprappro.com]
You will only see the Tools > Board > Boards Manager menu in Arduino IDE version 1.6.2 and later. It installs bossac in a different place from 1.6.1, which is what I was explaining earlier in the thread.
And we know the 'gui' version of Bossa doesn't work, which is why we don't link to it!
Ian
May 20, 2015 03:33PM
Hi Ian,
Thanks for the input.
Not sure why, but I had it stuck in my head that version 1.0.6 was the last that would run on a 32bit machine - duh. So I have now installed 1.6.1 and i can see that bossac is there.
My next problem is that the Mac is not recognising the duet board on the USB port........
Ralph
May 20, 2015 04:24PM
Mac has issues when you reset the duet, I use my work windows for the firmware, no choice. Using windows on a virtual machine also does not work
----- Making the world smarter @ www.xetal.eu
----- Helping entrepreneurs @ www.fralke.com
May 20, 2015 05:29PM
Hi Ralph
There's a Mac-specific firmware update problem thread (with more explanation, and tests) here: [forums.reprap.org]
Please post your Mac connections problems there. At the moment, it generally seems Macs can see the Duet when it has firmware, but some can't when the firmware is erased. I really don't know why this is! If you can post your experience on the above thread, it may help resolve this problem.
Ian
