Is there an stl file of the bed ? January 24, 2014 03:46PM |
Re: Is there an stl file of the bed ? January 24, 2014 04:10PM |
alanbattersby
....Could someone also tell me what function the cardboard piece has. Is it thermal insulation or to absorb jolts etc. I ask because I am considering using some Silicone rubber I have, to cast a replacement mat for the cardboard. I thought it would be tougher but just as forgiving. Is this a good idea?
Alan
Re: Is there an stl file of the bed ? January 24, 2014 04:13PM |
Re: Is there an stl file of the bed ? January 24, 2014 04:23PM |
Re: Is there an stl file of the bed ? January 24, 2014 04:54PM |
Re: Is there an stl file of the bed ? January 25, 2014 02:07PM |
Re: Is there an stl file of the bed ? January 25, 2014 03:09PM |
rayhicks
I've been mulling over the merits of various materials I have to hand for this (should I get round to making a rigid bed) : - 1mm neoprene foam, 3mm corolux, 2mm cork, 2mm polythene foam sheet (hard flooring underlay, on a roll from homebase), two part silicone (not much chance without foaming) or space filling PU foam - most of these have a lot of merits and all have a working temperature high enough for the bed, and if I do make a rigid bed I'll compare some with corrugated cardboard (which is probably a winner on most points and maybe overall depending on how you weight the benefits, particularly if price has a positive weighting )
Re: Is there an stl file of the bed ? January 25, 2014 03:13PM |
Re: Is there an stl file of the bed ? January 25, 2014 03:35PM |
Re: Is there an stl file of the bed ? January 25, 2014 03:38PM |
Re: Is there an stl file of the bed ? January 25, 2014 04:17PM |
Re: Is there an stl file of the bed ? January 25, 2014 04:44PM |
Re: Is there an stl file of the bed ? January 25, 2014 05:00PM |
Re: Is there an stl file of the bed ? January 27, 2014 05:42AM |
Re: Is there an stl file of the bed ? October 14, 2014 09:00PM |
