Is there any good reason not to print PLA direct on glass? January 24, 2014 06:33PM |
Re: Is there any good reason not to print PLA direct on glass? January 24, 2014 07:09PM |
Re: Is there any good reason not to print PLA direct on glass? January 24, 2014 07:15PM |
Re: Is there any good reason not to print PLA direct on glass? January 24, 2014 07:18PM |
Re: Is there any good reason not to print PLA direct on glass? January 24, 2014 07:28PM |
Re: Is there any good reason not to print PLA direct on glass? January 25, 2014 05:19AM |
Re: Is there any good reason not to print PLA direct on glass? January 25, 2014 07:26AM |
dc42
Having struggled with applying Kapton tape, and experimented with using Marley solvent pipe adhesive instead, I'm now getting good results printing direct on glass.
So I'm wondering why RRP and others bother with the Kapton tape? Is there some advantage to using Kapton with PLA that I have missed?
For anyone interested in trying this:
1. Set slic3r to use a bed temperature of 80C for the first layer and 65C for subsequent layers. Note: you also need to edit the "Custom gcode" in the Printer settings, to set 80C bed temperature.
2. Remove fingermarks etc. from the glass with acetone or isopropanol.
3. Start heating the bed to 80C, and home the X and Y axes.
4. While the bed is heating up, wipe it with a paper towel moistened in vinegar, then wipe it dry. [I don't yet know whether this is really important, or what else would work in place of vinegar.]
5. When the bed has reached 80C, home the Z axis, and run the auto bed compensation if you are using it.
6. Start the print.
7. When the print has finished, allow it to cool down, then it will be easy to remove from the glass.
Re: Is there any good reason not to print PLA direct on glass? January 25, 2014 01:03PM |
Re: Is there any good reason not to print PLA direct on glass? January 27, 2014 04:09AM |
