Re: Cura 14.01 March 05, 2014 06:31AM |
Re: Cura 14.01 March 05, 2014 06:43AM |
Re: Cura 14.01 March 05, 2014 07:24AM |
Hi Mancinism,Quote
mancinism
I wonder does Cura has the option similar to Extrusion Multiplier and calibrate the object dimension? Thanks
Re: Cura 14.01 March 06, 2014 12:17PM |
Re: Cura 14.01 March 07, 2014 07:20AM |
Re: Cura 14.01 March 07, 2014 11:27PM |
Re: Cura 14.01 March 08, 2014 05:37AM |
Re: Cura 14.01 March 08, 2014 05:32PM |
dmould
Hmmm - well I've done a few prints with Cura, and found that some layers are inexplicably printed at very slow speed (looks about 20mm/s or less) whilst others print at the 100mm/s I have set. That's both perimeters and infill. The parts I've been printing printing have 2 different sections, and on some layers the perimeter & infill of one section prints fast, and the other slow. I've tried setting all the speeds in Cura to 100mm/S (even the extruder retract speed!), but the slow layers still occur at random, about 3 out of every 5 layers - nothing special in the slow layers. I'm not sure at this stage whether it is Cura or the firmware that is the cause - I'll have to look into the G code, and try the same part sliced with Slic3r.
Dave
(#106)
Re: Cura 14.01 March 09, 2014 01:30PM |
Re: Cura 14.01 March 09, 2014 04:28PM |
Re: Cura 14.01 March 09, 2014 04:57PM |
Re: Cura 14.01 March 10, 2014 08:37AM |
KP
EDIT: I can't get it to break by doing the following:
Using the Ormerod plugin, all G0 moves are converted to G1 as expected and a brief scan of the extrusion values seems to make sense.
- Drag & drop a model file
- Re-enable the plugin at ~50% slice progress bar
- Save before slice completion
Kev.
Re: Cura 14.01 March 10, 2014 08:46AM |
antlvk
I'ts more like the software itself as it crash if i click somewhere while in the slicing mode. or even if it finish slicing it will undim the print button and nothing happen.
\BTW here is the code
;Generated with Cura_SteamEngine 13.12
M140 S60.000000
M109 T0 S205.000000
T0
M190 S60.000000
G21
G90 ; use absolute coordinates
M83 ; use relative distances for extrusion
M140 S65; Set bed temperature
G1 Z5 F200 ; lift nozzle
G1 X2 Y50 F2000; Go to wait for warm position
M116; Wait for all temperatures
G10 P0 S205 R0 ; Set extruder temperature
T0; Select extruder
;Layer count: 336
;LAYER:0
M107
G1 F1800.000 E-1.0
G1 Z0.30
G1 F2940 X90.21 Y55.63
G1 F1800.000 E1.0
;TYPEKIRT
Re: Cura 14.01 March 10, 2014 09:27AM |
Re: Cura 14.01 March 11, 2014 05:07AM |
Re: Cura 14.01 March 11, 2014 05:12AM |
antlvk
I'm running on latest firmware. I tried send manually, can print but print levitated
Re: Cura 14.01 March 13, 2014 03:14PM |
Re: Cura 14.01 March 13, 2014 04:30PM |
Re: Cura 14.01 March 13, 2014 04:37PM |
Re: Cura 14.01 March 15, 2014 02:04PM |
Re: Cura 14.01 March 15, 2014 02:51PM |
Re: Cura 14.01 March 16, 2014 02:06PM |
Re: Cura 14.01 March 17, 2014 06:39AM |
Re: Cura 14.01 March 17, 2014 07:21AM |
defaults write com.apple.Finder AppleShowAllFiles YES
Re: Cura 14.01 March 17, 2014 08:11AM |
Re: Cura 14.01 March 17, 2014 08:17AM |
Re: Cura 14.01 March 17, 2014 08:23AM |
Re: Cura 14.01 March 17, 2014 10:36AM |
Re: Cura 14.01 March 17, 2014 11:08AM |
Re: Cura 14.01 March 17, 2014 11:24AM |
