Cura 14.01
Posted by Anonymous User
Re: Cura 14.01
March 05, 2014 06:31AM
After tested Frank's plugin, Cura does produce better printing than Slic3r. But I am having problem with the object printed is slightly smaller in X and Y axis. I manage to re-calibrate the Extrusion Multiplier in Slic3r using a single wall cube.
I wonder does Cura has the option similar to Extrusion Multiplier and calibrate the object dimension? Thanks
Re: Cura 14.01
March 05, 2014 06:43AM
Alternatively you can change the Ormerod steps/mm using the M92 command. The default values set in the firmware are:
X87.4890 Y87.4890 Z4000.0
Re: Cura 14.01
March 05, 2014 07:24AM
mancinism
Hi Mancinism,
Cura has "Flow%" under the simple settings tab, in the filament section - use it like slic3r's extrusion multiplier, but use percentages rather than decimal fractions (eg 90% insead of 0.9)
Ray
Edited 1 time(s). Last edit at 03/05/2014 07:24AM by rayhicks.
Re: Cura 14.01
March 06, 2014 12:17PM
Totally won't start to print.... got cura 14 and the plugin...
Re: Cura 14.01
March 07, 2014 07:20AM
antlvk
Could you post the first 20 or so lines of the G code that Cura produced? It might hold the clue as to where the problem lay.
Dave
(#106)
Re: Cura 14.01
March 07, 2014 11:27PM
I'ts more like the software itself as it crash if i click somewhere while in the slicing mode. or even if it finish slicing it will undim the print button and nothing happen.
\BTW here is the code
;Generated with Cura_SteamEngine 13.12
M140 S60.000000
M109 T0 S205.000000
T0
M190 S60.000000
G21
G90 ; use absolute coordinates
M83 ; use relative distances for extrusion
M140 S65; Set bed temperature
G1 Z5 F200 ; lift nozzle
G1 X2 Y50 F2000; Go to wait for warm position
M116; Wait for all temperatures
G10 P0 S205 R0 ; Set extruder temperature
T0; Select extruder
;Layer count: 336
;LAYER:0
M107
G1 F1800.000 E-1.0
G1 Z0.30
G1 F2940 X90.21 Y55.63
G1 F1800.000 E1.0
;TYPEconfused smileyKIRT
Re: Cura 14.01
March 08, 2014 05:37AM
tried cura 13 same thing . crash or nothing happen.
Re: Cura 14.01
March 08, 2014 05:32PM
dmould
Hmmm - well I've done a few prints with Cura, and found that some layers are inexplicably printed at very slow speed (looks about 20mm/s or less) whilst others print at the 100mm/s I have set. That's both perimeters and infill. The parts I've been printing printing have 2 different sections, and on some layers the perimeter & infill of one section prints fast, and the other slow. I've tried setting all the speeds in Cura to 100mm/S (even the extruder retract speed!), but the slow layers still occur at random, about 3 out of every 5 layers - nothing special in the slow layers. I'm not sure at this stage whether it is Cura or the firmware that is the cause - I'll have to look into the G code, and try the same part sliced with Slic3r.
Dave
(#106)
Hi Dave,
Did you work this out?
I set the print speed, travel speed and infill speed at 100m/s but currently its printing extremely slow. but a couple of minutes ago 1 layer printed really fast. Random!
Cheers
Paul
Re: Cura 14.01
March 09, 2014 01:30PM
My problem disappeared when I uninstalled all the Cura versions I had on my PC, and re-installed just the latest. But I just realised something about Cura today:
When you drag an STL into Cura or make certain other changes, the plugin disappears and there is a small progress bar in the top left of the render window which disappears after a while. You must not do anything while that progress bar is present else there may be errors in the G code. It appears that Cura slices the print as soon as you make changes - which is why it is so quick when you save the G code - but it doesn't like you changing things while it is slicing. If, for example, you drag a new STL into Cura and immediately add the plugin, the G file will not be modified by the plugin. You have to wait for the progress bar to go before adding the plugin, and then wait for the new progress bar to go before saving the G code.
Dave
(#106)
Re: Cura 14.01
March 09, 2014 04:28PM
Thanks Dave.
I didn't try to re install Cura to correct my speed issue, but i did update the firmware to DC42's 'T' firmware, and i updated the web interface.
All working ok now! No idea why i had the problem in the first place.
Cheers
Paul
KP
Re: Cura 14.01
March 09, 2014 04:57PM
Yes, Cura (re)generates the G-Code in the background. Altering any of the parameters (including for a plugin) causes a regeneration, even if one is already in progress. For me, enabling a plugin causes regeneration too (Cura 14.01).
I have not checked the produced G-Code for errors though. I will attempt to do so.
File->Load / File->Recent do not disable plugins.
I have raised an issue on GitHub.
EDIT: I can't get it to break by doing the following:
  1. Drag & drop a model file
  2. Re-enable the plugin at ~50% slice progress bar
  3. Save before slice completion
Using the Ormerod plugin, all G0 moves are converted to G1 as expected and a brief scan of the extrusion values seems to make sense.
Kev.
Edited 1 time(s). Last edit at 03/09/2014 05:12PM by KP.
Re: Cura 14.01
March 10, 2014 08:37AM
KP
Kev.
Odd. If I save the G code while the progress bar is working, the G code is incomplete (does not have the end code) even though Cura said it saved it correctly. If I activate the plugin while the progress bar is visible, the G code is not modified by the plugin. It may well depend on the version of Cura.
I happen to be using pretty high-power PCs to slice and connect to the Ormerod, because they are the same PCs I use for other CAD work, so I only see the progress bar appear at all for quite large prints, and then just for a couple of seconds, which is why I have only just noticed it. If however I were to set up a dedicated Ormerod print station, I'd be using a cheap slow PC for the job - and in that case the slicing could well take minutes rather than seconds, so it's certainly something to watch out for.
Dave
(#106)
Re: Cura 14.01
March 10, 2014 08:46AM
antlvk
M140 S60.000000
M109 T0 S205.000000
T0
M190 S60.000000
G21
T0; Select extruder
;Layer count: 336
;LAYER:0
M107
G1 F1800.000 E-1.0
G1 Z0.30
G1 F1800.000 E1.0
I cannot see any reason why the print doesn't start. Maybe try sending those commands by hand and see where the Ormerod stalls. I see that you are using the G10 command to set the extruder temperature. I have used that command in the past and it should work, but a better command to use is the M104 command. Does the bed and extruder get to temperature OK, or is it maybe stalling on one of the M116 positions?
If you have not loaded DC42's firmware, you should definitely do so. The acceleration bug in the RepRap firmware is a complete show-stopper as far as I am concerned, and used to cause me all sorts of print problems that I had been thinking were hardware related, as well as limiting the speed to a fraction of what the Ormerod is capable of - my prints were taking 4 times longer than they needed to take.
Here is the start code I use in Cura - maybe try it and see if that fixes the issue:
G21
G90 ;absolute positioning
M203 X6000 Y6000 Z240 E3000 ; Allows 100mm/s speeds
M140 S{print_bed_temperature} ; Set bed temp
M116; Wait for bed temperature
T0 ; Select extruder 0
M104 S{print_temperature} ; Set extruder temp
M116; Wait for extruder temperature as well
Dave
(#106)
Re: Cura 14.01
March 10, 2014 09:27AM
Antlvk - one thing in the gcode that could stop the print is the "T0" command - there was a bug in early versions of the firmware that would prevent printing if an extruder was chosen twice (T0 selects extruder 0, T1 would select the second extruder if there was one, etc). I pointed this out to RRP in December I think, and they fixed it immediately, so if you're running a current version of firmware (either 0.57a or dc42's 0.57t), this shouldn't be the cause - if you're running older firmware then it might be, and I'd recommend you update to dc42's current release,
Ray
Re: Cura 14.01
March 11, 2014 05:07AM
I'm running on latest firmware. I tried send manually, can print but print levitated
Re: Cura 14.01
March 11, 2014 05:12AM
antlvk
antlvk, please can you read this post [forums.reprap.org] and reply to it with the data requested. I'd like to get to the bottom of this today.
Re: Cura 14.01
March 13, 2014 03:14PM
Hi all,
now the files are on a Github repository: https://github.com/Cash70/EAtoR !
The Plugin now contains a modification from the forums user "KP" with 2 additional parameters to set a new temperature (bed and extruder) after the first layer!
Cheers, Frank
Re: Cura 14.01
March 13, 2014 04:30PM
Hi Frank,
The new plugin wont show for me?
When i put the old plugin back into the folder it comes up though?
Any ideas?
Thanks
Paul
EDIT - ignore me. i right clicked and save as. so it was a html file instead
ill give it a go now
Edited 1 time(s). Last edit at 03/13/2014 04:32PM by PaulHam.
KP
Re: Cura 14.01
March 13, 2014 04:37PM
If you look in 'output.txt' in the Cura directory and search for 'EAtoR.py' at the end of the file, what is the error associated with it?
Kev.
Ignore me too. Unless you have any problems with the plugin.
Edited 1 time(s). Last edit at 03/13/2014 04:38PM by KP.
Re: Cura 14.01
March 15, 2014 02:04PM
hello!
trying to 'upgrade' to Cure 14.01 as i've heard it does a much better job of supports that slic3r.. havning a few problems though.
(I'm working on a Mac for the record)
ive read through the forum for tips and instructions.
1. I downloaded the plugin Cash and KP have kindly done but i dont know if im using this correctly... i have dragged all the contents of the folder;
current profile.ini
prefrences.ini
readme.md
EAtoR.py...... into the "plugins" folder.
after closing + reopening Cura can see the plugin as shown in attached image..
2. i have also changed the start g-code to Dmould's reccomendation;
;Sliced at: {day} {date} {time}
;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density}
;Print time: {print_time}
;Filament used: {filament_amount}m {filament_weight}g
;Filament cost: {filament_cost}
;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line
;M109 S{print_temperature} ;Uncomment to add your own temperature line
G21 ;metric values
M203 X6000 Y6000 Z500 E3000 ; Allows 100mm/s speeds
...again image attached
3. i have also gone thorugh and changed a couple of the filament settings, layer thickness, etc to match the slic3r that works adequately. smiling smiley
images attached
.... when I clicked to print the file, there was just a REALLY LOUD noise and the nozzle just moved extremely slowly in the direction of the 'P2' corner.
any thoughts? sad smiley really want to be able to use Cura
open | download - advanced.jpg (40.4 KB)
open | download - basic.jpg (45.1 KB)
open | download - plugin.jpg (25.9 KB)
open | download - start gcode.jpg (70 KB)
KP
Re: Cura 14.01
March 15, 2014 02:51PM
Are you printing direct from Cura? I've never tried that.
Can you slice a small simple object (see my attached .stl) and post it the G-Code as an attachment?
Kev.
Edited 1 time(s). Last edit at 03/15/2014 02:53PM by KP.
open | download - Zombies.stl (684 bytes)
Re: Cura 14.01
March 16, 2014 02:06PM
Hi 88Zombies,
I think the .ini files are not in the correct folder! They should not be in the "plugins" folder, only the plugin itself should be there!
The two .ini files should replace the original .ini files inside the Cura program folder "C:\Program Files (x86)\Cura_14.01\Cura" or the equivalent program folder on your MAC. Be sure to replace the original files!
Then be sure to check that the plugin is still active/activated every time you replace the 3D object.
Cheers, Frank
Edit: I think I should work on the readme file... winking smiley
Edited 2 time(s). Last edit at 03/16/2014 02:30PM by Cash.
Re: Cura 14.01
March 17, 2014 06:39AM
Hi KP,
Ah thank you! I will give that a go tonight (sorry late reply, busy weekend).
No im using Cura to create the Gcode then printing the gcode from proterface.
I'll post the G-code as soon as i get home.
Hi Cash,
Ah i think that could be where the problem is occuring...
I did try to find a cura foulder but can't seem to find it anywhere! i looked in 'library', 'applications'...
tried searching online to find where but no such luck sad smiley
haha no i think the read me file is just fine, i did think i was doing somthing wrong when i put all the files into the 'plugins' folder but im such a noob i couldn't (and still can't) find the correct folder.
thank you both! smiling smiley
Edited 2 time(s). Last edit at 03/17/2014 06:40AM by 88Zombies.
Re: Cura 14.01
March 17, 2014 07:21AM
Zombies - if you looked in "applications" and "libraries", I presume you're using a mac -right? If so I had this same problem, the Cura folder for plugins on macintosh is in your home directory, and it's called /.cura .
The dot before the name makes it invisible unless you work some magic:
open the terminal, then paste this:
defaults write com.apple.Finder AppleShowAllFiles YES
then hit the enter/return key
next you need to restart the finder - hold down the "alt/option" key then right-click on the finder icon in the dock, choose "relaunch". lastly do a left-click on the finder icon and it will open a new window, navigate to "home" and you shoud be able to see the hidden dot-files. Open .cura and there should be a folder called plugins - if there isn't you can make one and drop the plugin into that.
Cheers
Ray
Edited 1 time(s). Last edit at 03/17/2014 07:32AM by rayhicks.
Re: Cura 14.01
March 17, 2014 08:11AM
Boom! that would explain why, (after about an hour searching through just about every folder) i still couldn't find it.
thanks again Ray, i'll have a hunt for .cura this evening!! smiling smiley
Re: Cura 14.01
March 17, 2014 08:17AM
Win7:
C:\Program Files (x86)\Cura_14.01\Cura\preferences.ini
C:\Program Files (x86)\Cura_14.01\Cura\current_profile.ini
C:\Program Files (x86)\Cura_14.01\Cura\plugins\EAtoR.py
Erik
Re: Cura 14.01
March 17, 2014 08:23AM
I have attempted a fix for absolute extruder moves in my latest firmware. See [forums.reprap.org].
Re: Cura 14.01
March 17, 2014 10:36AM
oooo I shall install this tonight DC42. what is an "absolute extruder move"??
currently using your 057R and is working great btw, it's much appreciated smiling smiley
Edited 1 time(s). Last edit at 03/17/2014 10:37AM by 88Zombies.
Re: Cura 14.01
March 17, 2014 11:08AM
Absolute extruder moves are what Cura outputs if you don't use Frank's plugin.
Re: Cura 14.01
March 17, 2014 11:24AM
Zombies,
by the way, the ini files go inside the same .cura folder,in a subfolder named after the cura version but the best way to use them is to choose "Open profile..." from the file menu.
As dc42 says, Cura uses absolute extruder positions by default - Frank had to write the plugin so that Cura output would be compatible with Ormerod. Absolute moves tell the Ormerod where it should be, relative moves tell the ormerod to move a little bit further than where it is now. Most software appears to generate absolute moves for X, Y and Z - for Extrusion slic3r defaults to absolute and Cura only has absolute. The duet firmware was intended to take either, but there's a bug if absolute moves are used for extrusion where the firmware would retract the extruder all the way to the start of the filament if it was zeroed during a print (up to 20 metres or so, which takes a long time and ejects the filament totally, and is impossible to continue from). Hopefully this revision will fix that bug, and people will be able to use Cura without a plugin, and also use slic3r without checking the "use relative E distances" box - a common problem for first timers (also causing a problem if trying to print copies of the RRP factory gcodes for spare printer parts since these have absolute E distances I think).
If this fix works you may not need to get the plugin working (but you will need to have suitable printer settings still in Cura - particulary setting the origin to 0,0 and setting the printable area to 200x200x200 or so)
Ray
