Rebuilt the bottom Half January 27, 2014 12:14PM |
Re: Rebuilt the bottom Half January 27, 2014 12:58PM |
Re: Rebuilt the bottom Half January 27, 2014 01:00PM |
Re: Rebuilt the bottom Half January 27, 2014 01:01PM |
Re: Rebuilt the bottom Half January 27, 2014 01:45PM |
Re: Rebuilt the bottom Half January 27, 2014 02:19PM |
Re: Rebuilt the bottom Half January 27, 2014 02:52PM |
Re: Rebuilt the bottom Half January 27, 2014 04:35PM |
Re: Rebuilt the bottom Half January 27, 2014 09:36PM |
Re: Rebuilt the bottom Half January 28, 2014 02:45AM |
johneato
Erik
The weight is about 320 grms against the original that came in at about 110grms. So its about 3 times the weight, but when you factor in the weight of the aluminum and glass the total weight increase as a percent is far less....
John
Re: Rebuilt the bottom Half January 28, 2014 03:20AM |
Re: Rebuilt the bottom Half January 28, 2014 04:01AM |
Re: Rebuilt the bottom Half January 28, 2014 04:13AM |
Re: Rebuilt the bottom Half January 28, 2014 04:30AM |
The glass does deform and can be measured. The bed is mounted on springs but doesnt help because the glass is clamped to the aluminium/ PCB by the edge clamps which do exert quite a force.Quote
dc42
I doubt that the aluminium by itself is stiff enough to bend the glass much. I suspect it is the alu and pcb sandwich together that is providing the stiffness, aided by the corner screws. Some people have used springs to support the weight of the bed in order to make levelling easier, and this might have the beneficial effect of clamping the alu less tightly to the pcb.
Re: Rebuilt the bottom Half January 28, 2014 04:49AM |
johneato
The glass does deform and can be measured. The bed is mounted on springs but doesn't help because the glass is clamped to the aluminium/ PCB by the edge clamps which do exert quite a force.
Re: Rebuilt the bottom Half January 28, 2014 05:44AM |
Re: Rebuilt the bottom Half January 28, 2014 06:20AM |
GregL
Try cannibalising a retractable ballpont pen
Re: Rebuilt the bottom Half January 28, 2014 06:23AM |
Re: Rebuilt the bottom Half January 28, 2014 07:40AM |
Re: Rebuilt the bottom Half January 28, 2014 07:52AM |
Re: Rebuilt the bottom Half January 28, 2014 08:04AM |
Re: Rebuilt the bottom Half January 28, 2014 08:13AM |
Re: Rebuilt the bottom Half January 28, 2014 11:15AM |
Re: Rebuilt the bottom Half January 28, 2014 11:23AM |
Re: Rebuilt the bottom Half January 28, 2014 01:47PM |
johneato
Kim :-
The material is Poycarbonate, a couple of years ago I bought a large amount from an old hardware shop that was closing down. It is in 500 x 300mm sheets and labelled as aircraft screens. It machines and taps very well and is incredible strong. A significant amount of my CNC is constructed with it.
Ian:-
I did fit the two extra screw terminals and reprinted the Duet enclosure with an extra opening. I attached two further 3 way screw connectors to the front of the heater PCB.
John
Re: Rebuilt the bottom Half January 28, 2014 03:25PM |
Re: Rebuilt the bottom Half January 28, 2014 04:07PM |
Re: Rebuilt the bottom Half January 28, 2014 04:12PM |
Re: Rebuilt the bottom Half January 28, 2014 04:14PM |
Re: Rebuilt the bottom Half January 28, 2014 04:18PM |
