Alternative bed proposal January 31, 2014 05:04PM |
Re: Alternative bed proposal January 31, 2014 05:56PM |
Re: Alternative bed proposal January 31, 2014 07:30PM |
Re: Alternative bed proposal February 01, 2014 03:03AM |
Re: Alternative bed proposal February 01, 2014 04:24AM |
Re: Alternative bed proposal February 01, 2014 03:12PM |
Re: Alternative bed proposal February 01, 2014 06:42PM |
dc42
I took some measurements using 3mm glass, then switched to 4mm and remeasured.
Using 3mm glass, the centre of the bed was 0.175mm higher than the average of the corners. Using 4mm glass, the centre is 0.075mm higher than the average of the corners.
This is a useful improvement. I used the same 9mm photo frame clips, so the clamping force will be a little higher using 4mm glass. I currently have 3.3mm hardboard under the glass for the clips to lock into, so I'll try using something thinner such as a piece of copper-clad board next.
Re: Alternative bed proposal February 02, 2014 07:48AM |
Re: Alternative bed proposal February 02, 2014 08:08AM |
Re: Alternative bed proposal February 02, 2014 10:45AM |
ormerod168
Notice how the force of the tube is at its hight in the middle of the bed
X25 Z0.0
X50 Z0.1
X75 Z0.1
X100 Z0.2
X125 Z0.2
X150 Z0.1
X175 Z0.05
X200 Z0.0
Re: Alternative bed proposal February 25, 2014 05:00PM |
Paul, did you get you bed laser cut?Quote
PaulHam
ive just had a little play around with the standard bed file in the master directory.
Ive never done anything like this before so what do you think?
What format does it need to be for a lasercutter to use it?
Re: Alternative bed proposal February 25, 2014 06:00PM |
Re: Alternative bed proposal February 25, 2014 06:05PM |
Re: Alternative bed proposal February 25, 2014 07:48PM |
Re: Alternative bed proposal February 26, 2014 02:52AM |
Re: Alternative bed proposal February 26, 2014 03:56AM |
Re: Alternative bed proposal February 26, 2014 05:06AM |
epninety
...I only need cut to size and drill a few holes before I can try it out. It could be simply taped to the MDF for first tests...
Dave
Re: Alternative bed proposal February 26, 2014 05:45AM |
Re: Alternative bed proposal February 26, 2014 06:27AM |
Treth
PaulHam
If so how good is it and do you recommend?
Re: Alternative bed proposal February 26, 2014 06:30AM |
epninety
....plus the (3?) countersunk holes where the MDF is screwed to the rib and bearings...
Re: Alternative bed proposal February 26, 2014 07:39AM |
PaulHam
Treth
PaulHam
I got some quotes but it wasn't anything I would spend.
Made out of 3mm Alu, £250, £200 & £50
So I have moved the aluminium heat spreader down on top of the mdf bed. its better than before but stil not perfect as it still rocks on the rib.
Re: Alternative bed proposal February 27, 2014 09:29AM |
Re: Alternative bed proposal February 27, 2014 09:32AM |
Re: Alternative bed proposal February 27, 2014 09:40AM |
Re: Alternative bed proposal February 27, 2014 03:50PM |
But also look at PaulHam's post [forums.reprap.org] where he provides a good dimensioned triangular bed similar to DC42s picture.Quote
djar
I would try a new bed construction aswell. Therefor I'm looking for the files of the original lasercut parts. Any idea where they hide?
[github.com]
There is the y-rib and the y-cross-rib - but the top?
Re: Alternative bed proposal February 27, 2014 05:05PM |
Re: Alternative bed proposal February 27, 2014 05:36PM |
My proposal is just for a level stable bed (with removable glass (point #4)). You can use Kapton tape, pipe cement or just plane glass which ever you choose. I don't seem to have any problems with my original Kapton taped glass so have stayed with that.Quote
KimBrown
Hmmmm I print on glass, and the only way I can get it to stick is to remove the glass and wash it with washing up
liquid, air dry, then mount.... Also I've found that removing the prints is easy... I put print and glass under the cold tap, and the print float off..
Re: Alternative bed proposal March 02, 2014 03:19PM |
Re: Alternative bed proposal March 02, 2014 04:06PM |
Re: Alternative bed proposal March 09, 2014 06:59PM |
