z- axis nut (long brass) supplier February 01, 2014 03:18AM |
Re: z- axis nut (long brass) supplier February 01, 2014 04:48AM |
Re: z- axis nut (long brass) supplier February 01, 2014 04:56AM |
FalseIdle
I searched eBay after reading the thread suggesting a longer brass z nut but failed to see one.
Re: z- axis nut (long brass) supplier February 01, 2014 05:07PM |
Re: z- axis nut (long brass) supplier February 01, 2014 08:37PM |
Re: z- axis nut (long brass) supplier February 02, 2014 03:30AM |
From the ebay link their postage price to rest of world is £3 which bumps up the cost!Quote
tru168
I'm still searching for one. Seems unlikely to order because I'm in Asia, but good to know the keyword to search online.
Thanks !
Re: z- axis nut (long brass) Important Update! February 02, 2014 08:09AM |
Re: z- axis nut (long brass) supplier February 02, 2014 01:09PM |
Re: z- axis nut (long brass) Important Update! February 02, 2014 01:45PM |
Re: z- axis nut (long brass) Important Update! February 02, 2014 04:49PM |
Treth
IMPORTANT
I made enquiries with the ebay supplier but did not receive a response so followed up with NNC....
-----Original Message-----
Sent: 31 January 2014 20:30
To: sales@nccsupplies.com
Product Required: JDY01.M05 can you confirm this is a parallel thread and continuous from end to end, i.e. has been taped from one end and an M5 stud could run through this.
REPLY
Hello Kevin
Thank you for your enquiry.
This product would not be suitable for your purpose
Kind regards
Richard
As it does not suggest why and my supplied part appears to work, I have asked for more details, but please be aware of this response.
I have also ordered a few more to confirm my initial findings.
Re: z- axis nut (long brass) Important Update! February 03, 2014 01:47AM |
Treth
....a right hand thread one end and a left hand thread the other end....
Re: z- axis nut (long brass) Important Update! February 03, 2014 03:11AM |
ormerod168
Treth
If this is true then it must be a length adjusting nut - to adjust the total length of two rod with the nut in between, turn to one side, you pull them together, turn to the other side you push them apart
Erik
Re: z- axis nut (long brass) Important Update! February 04, 2014 11:52AM |
Re: z- axis nut (long brass) Important Update! February 05, 2014 06:30AM |
Treth
Got my repeat order from ebay supplier today and can confirm it is the same as the original supplied, i.e. hex rod approx 12.5mm long and M5 tapped, so should be good.
The part (JDY01.M05) is available on ebay [www.ebay.co.uk]
Let me know if anyone else tries these out.
Re: z- axis nut (long brass) Important Update! February 05, 2014 06:42AM |
kwikius
Treth
Just got mine in the post. Fits fine. Well recommended mod with a stainless steel z threaded rod! Thanks for the link!
regards
Andy
Re: z- axis nut (long brass) Important Update! February 05, 2014 08:53AM |
Re: z- axis nut (long brass) Important Update! February 06, 2014 03:36AM |
Re: z- axis nut (long brass) supplier February 06, 2014 06:59PM |
Re: z- axis nut (long brass) supplier February 12, 2014 07:07AM |
Re: z- axis nut (long brass) supplier February 12, 2014 07:33AM |
Hi Radian, yes I get a similar movement, but for me it is the same as I got with the original supplied steel nuts and standard brass nuts that I tried as I mentioned in the original post. I had expected less movement with the longer nut which is why I explored the part design with one of the suppliers (but their technical support did not seem to understand the part they were selling, stating it had left and right handed threads!).Quote
Radian
I ordered some JDY01.M05 as well but they're a bit sloppy on the original Z rod. With the original steel nut I couldn't measure any backlash at all but there's around 0.2mm with the new nut. This is measuring at the tip of the rod that hasn't been worn. Anyone else notice this?
Re: z- axis nut (long brass) supplier February 12, 2014 09:22AM |
Re: z- axis nut (long brass) supplier February 12, 2014 09:44AM |
