Test prints
February 02, 2014 05:38PM
I've just seen ormerod168's post about the Single Wall Alignment Test
Now I'm wondering what tests do you guys like to do to check your machine?
Also, I saw a comb on thingiverse and the description said each tooth was a different setting, is it possible to get slicer to used different settings in one print or have I got the wrong end of the stick?
Re: Test prints
February 02, 2014 06:46PM
I print this [www.thingiverse.com] at half size as a general check. It's no good for calibration, but it's quite a good test of bed adhesion (because the contact area is quite small) and the quality of overhangs and bridging.
Re: Test prints
February 03, 2014 08:10AM
Thanks dc
I will try your dodecahedron first.
How do you get it half size?, and are there any particular settings I should use with Slic3r?
Greg
Ormerod #17
Re: Test prints
February 03, 2014 08:24AM
You can scale it to half size in slic3r. The settings I use in slic3r are similar to the Ormerod 0.5 ones from RRP except that I set 4mm retraction, first layer 195C, other layers 190C, skirt separation 15mm, skirt loops 2.
Re: Test prints
February 04, 2014 01:18PM
Very pleased with my Dodecahedron.
A few wisps when trying to start the top pentagon.
Flushed with success, I graduated to the thin wall test.
Worked perfectly - except it is not watertight.
Pictures tomorrow.
Now to the problem:
It was quite happily running Matt's web interface, and dc's firmware before yesterday's trauma - all caused by me trying to fit my newly printed Zrunner.
Snapped Xrib nut holder, Y axis belt cable tie pulled through the plywood slot (when the axis jammed). Kim's elastic band keeping the ribbon cable taught going all wrong and bunching up underneath. The machine was regulalry upside down, bits disconnected, and verbally abused over several hours.
A bit of calm this morning got everything back together - and printing very successfully via Pronterface.
I can no longer run the web interface successfully,
The web page loads, but the Connect button is not enabled. The Send Gcode button is enabled, but nothing happens when I send, say, G1 X50
'get help here' takes me as usual to the forum page
Any ideas?
Greg
Ormerod #17
Re: Test prints
February 04, 2014 02:47PM
Matt updated the web interface yesterday, so if you are using the remote version, the new .js files you are picking up are no longer compatible with your old reprap.htm file.
Re: Test prints
February 04, 2014 02:57PM
Thanks dc. I'll sort that tomorrow.
Out of interest: where are the js files being picked up from?
I had naively thought as nothing had changed in the software here, that it should still run.
Testing web things must be a ****** nightmare.
Greg
Ormerod #17
Re: Test prints
February 04, 2014 04:17PM
Hi Greg,
The latest reprap.htm can be found on my github (link in my signature), if your not hosting the .js files on a web server local to you, use the reprap.remote.min.htm (renamed to reprap.htm).
feel free to ask if you need further help.
Matt
Limited Edition Red RS Ormerod 1 #144 of 200 - RRP 1.09fw
iamburnys Ormerod Upgrades Github
Follow me on ThingiVerse My Designs
Re: Test prints
February 04, 2014 04:22PM
iamburny
A word of warning: file reprap.remote.min.htm cannot be uploaded to the SD card via Pronterface. File reprap.remote.htm can be, if you rename it to reprap.htm first.
Edited 3 time(s). Last edit at 02/05/2014 05:58AM by dc42.
Re: Test prints
February 05, 2014 05:56AM
Try printing a lego block, there are quite a few on www.tinkercad.com, easy to use. I printed one over the weekend. Lego needs to be perfect to fit on a genuine lego block. My daughter was impressed. My first layer and rest were at 0.24 and my prints are still not perfect as I have a "flare" at the base which can be seen when fitting the printed block to other blocks. I have high standards, it must be perfect... What followed next was... Dad can you print this and that.... you are warned!
Dieter
#257
Re: Test prints
February 05, 2014 06:23AM
Well, two grandchildren went off yesterday playing with their dodecahedrons.
When they come back after school today, I expect they will each have a list of 'things to print'
As I am also expecting another two of the grandchildren to turn up today, I am already on my second dodecahedron of the day!!!
Help please: some time ago, someone posted a bearing with herringbone gears instead of rollers; I have searched for it - unsuccessfully. Does anyone have a link?
Greg
Ormerod #17
Re: Test prints
February 05, 2014 06:47AM
GregL
Greg
Gear Bearing
Check out the rest of his stuff. He is a true artiest.
Emmet
Dan.
Edited 1 time(s). Last edit at 02/05/2014 06:48AM by FalseIdle.
Re: Test prints
February 05, 2014 08:23AM
A bit of flaring at the base of a print is caused by zeroing the Z axis slightly too low before you start the print. IME it helps the print to stick, so is often necessary - a few strokes of a needle file or sanding block will fix it afterwards. Maybe print the grandkids some nautilus gears out of fluorescent or glow-in-the-dark filament. Or maybe a whistle - umm - on second thoughts, scrub that last suggestion!
Dave
(#106)
Re: Test prints
February 05, 2014 09:50AM
Thanks Dan,
I have downloaded the bearing - and bookmarked Emmet's web page.
Seeing his model of a sleeve valve engine has reminded me that I can now make a model of my T5 engine design: variable compression ratio, variable expansion ratio, variable capacity - all while the engine is running - and it has fewer components than a standard four stroke!
Meanwhile my fourth dodecahefron has not gone well. I noticed the extruder beginning to stutter fairly early on in the print. It eventually got worse and the print degenerated into a birds nest.
It was a repeat of my early extruder problem, with the small cog being forced closer to the extruder body - generating a lot of friction. A generous squirt of Lock Lube has returned the extruder to a much freer movement. Latest dodecahedron on its top pentagon, and looking good ( just in time - soon be off to collect two from school)
@Dave - I think I will give that whisle a miss!
Greg
Ormerod #17
Re: Test prints
February 11, 2014 05:11AM
Hi I have been running the thin wall test to determine the difference between different filaments I have here, the problem I am getting is that the wall thickness varies from 0.55 on the curved sections then down to almost 0.3 mm where the walls join is this a printer firmware issue or a slicr3 error?
thanks
Mike
Re: Test prints
February 11, 2014 05:45AM
Hi Mike,
I regularly do some tests with a one perimeter cube to adjust the extrusion multiplier ("filament settings" in slic3r).
I have the same oberservations as you have where from the start point (which annoyingly still has a blob at the point where it starts) the first wall is thinner than the rest, than begins to get thicker. The second wall is too thick, while the third an forth are somehow an average of both.
I did so many test already but still can't avoid either the blobby start (that is what is really a bad thing) nor the irregular thickness of the wall. As I do some prints now which have to be very accurate in size I almost gave up to try it with the Ormerod.
Markus
XBee & electronics blog: [lookmanowire.blogspot.com]
Re: Test prints
February 11, 2014 09:28AM
I had really bad blobs at the start of a layer, turned off 'Retract on layer change' and it has lessened the blobbyness. Still not perfect but better
Re: Test prints
February 11, 2014 09:51AM
Hi Paulham, I didn't have the retract enabled. my question relates to the wall thickness change as to whether the change is due to slicr not sending the right extruder feed info or some problem with the ormerod firmware .
regards
Mike
Re: Test prints
February 11, 2014 10:57AM
I printed the ThinWall test a few days ago in PLA with standard settings - I was very pleased with it, but it did not hold water
I would also show a picture of a Dodecahedron, but the forum software seems to think the file (at 608Kb) is too big for its stated limit of 614.4 Kb
The bearing Dan suggested turned out brilliantly 52mm dia and 15mm deep - with 5 planet herring-bone gears. It needed a sharp tap on the sun gear to unstick it, then tapping each of the planet gears in turn - now it runs quite smoothly. The current picture at 1.1Mb is too large - I will try and compress it.
Edited 1 time(s). Last edit at 02/11/2014 10:58AM by GregL.
Ormerod #17
Re: Test prints
February 11, 2014 11:01AM
More importantly, and where I need your collective wisdom, I have completed my first ABS print.
First layer temperatures 235, 105
Second and further layers 230, 100
Layer height 0.1
Splitting (noisy) occured during the printing on the curved corner nearest the Duet - and those parts of the wall buckled.
How can I improve things?
Greg
Ormerod #17
Re: Test prints
February 11, 2014 11:12AM
Here is that bearing (at least part of it)
Greg
Ormerod #17
Re: Test prints
February 11, 2014 12:09PM
Mickyblueeyes
Mike
Hi Mike
Just you have something to compare to - did a measurement on 2 of the same test cubes, 3 measurements each side taking care to measure in the same debt and with the same pressure on the micrometer
Print with ormerod original supplied white filament, C=curve, J=join, numbers x 0.01mm:
J, 60, 56, 56, C, 56, 55, 53, J, 52, 53, 53, C, 61, 60, 59
Print with 3DFilaPrint:
J, 58, 57, 56, C, 57, 58, 57, J, 59, 58, 55, C, 59, 58, 56
This was sliced in Slic3r 1.0.0RC2 and with dc42's ini files
Are you stretching the line?, should you adjust the feed?, have you tried adjusting the extrusion multiplier?
Disclamer: I know absolutely nothing about printing and share it gladly :-)
Erik
Re: Test prints
February 11, 2014 01:43PM
I have these measurements, taken using digital calipers:
J 51 53 54 C 64 55 54 55 J 54 53 53 C 56 53 55 54
The numbers immediately after the C are the middle of the corners. It almost holds water - overnight the level decreases by about 2% and a small pool appears around it. I am not getting any blobs, just a very slight roughness down the joins.
I'm trying that bearing now.
Re: Test prints
February 11, 2014 02:32PM
GregL
Layer height 0.1
Greg
I was getting warping and splitting with ABS as well. The corner closest to the Duet is indeed the most problematic - probably still something to do with fan wash despite the deflector.
The first thing to do is always try to orient parts on the bed (in Slic3r) so that there is no corner of the part in that orientation. I found that having a cooler bed for all but the first layer was better - I use 105 for the first layer and 90 for the rest. My extruder temperature is usually 250 for all layers. Keep a reasonably high ambient that does not change, and above all keep drafts away from the bed.
Dave
(#106)
Re: Test prints
February 12, 2014 05:38AM
HI ormerod168 and dc42, looks like I will have to learn more about the slicr3 settings I have Iamburny settings there at the moment but that doesn't change the results for this one, its as if it scrunches up on the corners and stretches out on the straights and ends.
regards
mike
Re: Test prints
February 12, 2014 08:05AM
Hi mike
I downloaded Iamburny's setting and made a compare show dif.
Ianburny's at the left, those I use at the right
Print:
Printer:
Filament:
Erik
Re: Test prints
February 12, 2014 09:11AM
thanks ormerod168 I will check it out, I am just rebuilding after doing the 5v psu repair to the circuit board
