Double Helix Z-Gears - iamburny Style cool smiley
Posted by iamburny
February 03, 2014 07:59AM
A few tiny tweaks to do and i'll post stl's and scad files for these.
Matt
Limited Edition Red RS Ormerod 1 #144 of 200 - RRP 1.09fw
iamburnys Ormerod Upgrades Github
Follow me on ThingiVerse My Designs
Re: Double Helix Z-Gears - iamburny Style cool smiley
February 03, 2014 08:13AM
Nice! - have you raised the supporting bearing inside the z-gear? - is the centerline of bearing, z-gear and motor-gear at the same horizontal level?
Erik
February 03, 2014 08:27AM
Matt you are a machine, soon 1/2 my printer will be designed by you.
They look very nice, noticed the Wades extruder my dad just got for his i3 had herringbone gears. Are there many benefits to them? They look a much tighter fit (less backlash?).
Dan.
February 03, 2014 08:42AM
@ormerod168 - I haven't moved the supporting bearing, I designed them to be a direct replacement. Because the teeth are herring bone (double helix) they pretty much level themselves, and its easy to tell if they aren't aligned properly.
@ FalseIdle - There is a "knack" to fitting them as the teeth mesh so closely, I was watching my original gears during printing and noticed a fair bit of slack between them, may have been as they were my own prints from a while back. These new ones are look/feel and sound a whole lot better.
Matt
February 03, 2014 01:05PM
Attached (in the zip file) is the seperate STL's for each gear and the scad for both.
If you want to use the scad you need you have the Involute Gears and Regular Shapes librarys available for scad to import.
The "knack" to fitting them is, put about 3 or 4mm of the stepper gear on motor shaft then put hex nut (on threaded rod) in the nut trap on other gear, check the gears mesh properly as they only fit on way round, once meshed, hold together tightly and slide both down at the same time until the hexnut gear is bedding onto the bearing, run the Z up and down a few times to help that bed together properly.
Matt
Edited 3 time(s). Last edit at 02/03/2014 01:11PM by iamburny.
open | download - iamburnys_ZGearsHelical.zip (421.1 KB)
February 04, 2014 01:14PM
I printed these last night, they look really good and mate very nicely. I didn't have the Slic3r settings quite right so will reprint them tonight, but looking forward to trying them out, as well as the new extruder gear design.!
February 04, 2014 02:31PM
Just fitted your Z axis gears - at first test they appear to have less backlash. Before, I went down in 0.1mm increments until the first time I could just feel a sheet of paper being gripped, but then if I went up 0.1mm the paper was still weakly gripped, up another 0.1mm and the paper was loose then back down 0.1mm and still completely loose. With these gears there is no discernable difference whether I go up to the grip point or down to the grip point.
I also printed your extruder gears. They are a bit stiff to the point where the motor misses the occasional step just extruding into air. Putting up the current to 1A stopped that, but I have not yet tried a print with them. Perhaps they need to wear in.
Dave
(#106)
February 04, 2014 04:07PM
Hi Dave,
I was very careful with the distance between centre's and diameters of the gears, and when measured with my vernier caliper the new ones were +/- 0.05mm, I have noticed though with the particular PLA (blue) that i'm using at the moment i do get some shrinkage which maybe why the fit of mine is damn near perfect. Also there maybe other variables involved due to printer differences, slic3r setting etc. i'll happily compare dimensions with the ones you have printed if it will help
Matt
February 05, 2014 07:21AM
iamburny
Hi Dave,
Matt
No problem Matt, it's common for my gear prints to be a bit stiff at first, but they usually wear in fairly quickly - and these printed so well that I did not feel the need for a touch-up with a needle file, so they really are straight off the bed and onto my Ormerod, so it's probably a slight uneveness in my perimeters rather than anything to do with your excellent design. Couple of pix of your gears on my Ormerod - in black ABS.
Dave
(#106)
open | download - Zgears.jpg (317.1 KB)
open | download - Egears.jpg (326.3 KB)
February 05, 2014 08:34AM
Very nice Dave =)
hope they are working well for you,
I thought i'd give mine a serious test and printed the Single Wall Alignment Test at 50% scale and 0.12mm layer height, came out pretty good
February 05, 2014 10:12AM
It looks as though your Egears might be the answer to my extruder problem, Matt.
Over time the standard small gear is being forced towards the extruder body. Eventually the friction becomes too much, and the extruder starts to stutter - and prints fail.
Your gears should not exert any longitudinal forces (mind you, neither should the current design), so hopefully rubbing won't occur
Greg
Ormerod #17
February 05, 2014 11:18AM
I discovered that I had left a washer out between the big gear and the bearing after fitting the new gears. That was causing the friction, not your gears, which now work perfectly.
Greg, the gears do exert a longitudinal force - if they are not aligned. So if the small gear starts to wander along the motor shaft, it should be automatically pulled back into alignment by the big gear. Note that you must not fit the small gear onto the shaft first like you do with the original gears, it must be held in mesh with the large gear and both fitted together.
Dave
(#106)
February 06, 2014 11:51AM
Hi Matt
I printed out your two gears but I'm not sure if I've got my Slic3r settings correct as the hex hole for the nut has not worked out very well and the hole down the centre of the other gear doesn't have a flat on it, it has more of a slot. I took a while to use your *.scad file in openscad the attached file shows the error I found. Could you publish the settings used in Slic3r please thanks.
dave
open | download - error in iamburnys_ZGearsHelical(scad) file.txt (219 bytes)
February 06, 2014 12:17PM
Hi Dave,
I had corrected that error on the latest github versions of these gears, also bevelled the corners, thanks for spotting it though. smiling smiley
attached is my (zipped) g-code results from slic3r. might be worth checking the pre-print commands at the start before using them.
Matt
open | download - zgear-gcode.zip (433.2 KB)
February 06, 2014 02:00PM
Thanks for providing your upgrade parts on github Matt, I'll be printing your E gears tomorrow-I grabbed some from thingiverse last month but they were for a larger extruder, and I've been wondering if I should try to design my own smiling smiley
Cheers
Ray
Edited 1 time(s). Last edit at 02/06/2014 02:01PM by rayhicks.
February 06, 2014 07:19PM
Love 'em, Love 'em, Love 'em hot smiley
Thank you so much @Iamburny for this beautiful upgrade. Like @dmould I was suffering from too much backlash and could easily get 0.2mm variation when trying to set Z=0, and this straight replacement has completely sorted that...a straight swop for a beautiful looking part that gives an immediate improvement in print quality - couldn't be happier!
I also remain childishly excited about watching my printer print it's own upgrades... spinning smiley sticking its tongue out
February 07, 2014 12:24PM
Endless thanks for the files for this upgrade, my printer suffered often from problems on the z-axis (stutter when moving, nut running out of the holder, and that all has been resolved with these gears!
Now I'm moving on to the other upgrades you've made available.
February 08, 2014 06:34AM
Matt, really appreciate all your work on this, I've just printed out your zgears from the the gcode you attached earlier and this is the cleanest, neatest, blob free print I've done so far.
Would it be possible to share the slic3r settings you are using?
I'd love to see what settings are different to the ones I'm using. I did notice it seems to print the second inner perimeter first, then the outer. How do you get slic3r to do this?
Tim
RS Ormerod #472
February 08, 2014 07:02AM
Hi Tim,
It is all about the slic3r settings, they can make or break a printer/print! I've attached my slic3r settings from "%USERPROFILE%\AppData\Roaming\Slic3r" they are a mix of official RRP, Dc42's and some of my own, some caution should be taken though as i print at a relatively cold 175C which although gives great results can put extra strain on the extruder stepper motor.
attached is a screenshot from my Slic3r (v1.0.0RC2), notice at the bottom "External perimeters first" is unchecked which helps improve the outer surface quality a fair bit.
Matt
February 08, 2014 07:10AM
Thanks Matt, but there's no attachment?
RS Ormerod #472
February 08, 2014 07:13AM
bah!, forgot to click attach button! sry
open | download - Slic3r.zip (3.9 KB)
February 08, 2014 11:43AM
Thanks Matt, that's brilliant, the difference in print quality is amazing!
What with this and your web interface I reckon I owe you at least a couple of pints!
Cheers, Tim smileys with beer
RS Ormerod #472
February 08, 2014 11:51AM
your round then Tim Cheers! drinking smiley
February 08, 2014 01:01PM
Hi Matt
A massive thanks from this side..... gears works a treat from the hotbed.
Well appreciated..
Now on to try and install your new web interface.. :-)
Thanks
Madmob
February 09, 2014 11:48AM
I just downloaded iamburny's Slic3r settings and it puts up an info box saying that Support material was improved since the last version and it recommends restoring to the default settings although it doesn't mention how to. The version I have is 1.0.0RC2 which looks like an increment since December. The only parameters for support material appear to be Pattern spacing (2.5mm) and Raft layers (0).
RS Components Reprap Ormerod No. 481
March 07, 2014 06:49AM
Mine a bit loose on the gear on the motor (EDIT) would it be bettter using PLA?
Edited 1 time(s). Last edit at 03/07/2014 07:01AM by antlvk.
March 07, 2014 07:17AM
Do I need to do any recalibration to the Zaxis settings after adding these gears?
Same question to the extrusion gears smiling smiley
Looks like some really good work, thank you! and thanks for the slic3r settings, i'll give those a whirl over the weekend! smiling smiley
March 07, 2014 07:21AM
No they are a straight swap!
March 07, 2014 07:32AM
Awesome, that's my kinda gear replacement. More for the printing list this weekend smiling smiley
September 08, 2016 06:40AM
Just so I dig out this subject a little, and to thank Iamburny for this excellent design and excellent Gcode files.
I had trouble printing these models to the correct size (holes ended up too small). I was beginning to think my Ormerod 2 could not achieve such precision. Then I got the gcode files from this thread and it does work, and beautifully.
Printing this showed me that my printer is capable and properly set up, and that I'm actually to blame for my poor results up to now... It was like having a master coming in my flat to show me how things are done. smiling smiley
For all that, thank you
And by the way the new z gears are indeed much better than the previous ones. Incredibly stable and precise.
