Stepped test print February 03, 2014 10:06AM |
Re: Stepped test print February 03, 2014 10:16AM |
Re: Stepped test print February 03, 2014 10:59AM |
Re: Stepped test print February 03, 2014 11:04AM |
Re: Stepped test print February 03, 2014 11:17AM |
Re: Stepped test print February 03, 2014 11:21AM |
rayhicks
It's likely that interference between the belt and the idler mount is the cause - if it's giving any real resistance to movement, then the motor will be stalling (missing steps) in one direction, this would lead to staggering in Y (much as a slipping belt would - but you say you've got this nice and tight). Is it possible to prevent the rubbing either by turning the belt around (if the teeth are outermost, then remove the twist so they're facing in), or perhaps by filing away the piece of plastic that the belt is interfering with?
Ry
Re: Stepped test print February 03, 2014 11:47AM |
Re: Stepped test print February 03, 2014 12:17PM |
Re: Stepped test print February 03, 2014 12:55PM |
Re: Stepped test print February 03, 2014 02:14PM |
Re: Stepped test print February 03, 2014 02:47PM |
Re: Stepped test print February 03, 2014 02:57PM |
Re: Stepped test print February 03, 2014 04:23PM |
Re: Stepped test print February 04, 2014 07:28AM |
Re: Stepped test print February 04, 2014 12:06PM |
Re: Stepped test print February 04, 2014 01:45PM |
appjaws1
Question do I need to do any set up to run the stl files or does Pronterface do it all for me?
Thanks again, a great form
regards
Paul
Re: Stepped test print February 04, 2014 07:14PM |
Re: Stepped test print February 05, 2014 07:48AM |
Re: Stepped test print February 05, 2014 02:59PM |
