Question about support material
Posted by alanbattersby
February 04, 2014 08:33AM
After doing a couple of straightforward parts, I have in mind to create something which would have quite a bit of overhang. So I am guessing some support would be required when printing. As I know nothing about this can someone point me to a useful basic information source? Does slic3R automatically add support material? Would I need to add another print head to my Omerod?
thanks
Alan
Re: Question about support material
February 04, 2014 11:13AM
Hi Alan
There's a section in the Slic3r manual about support material: [manual.slic3r.org]
We're working on a three-head machine, which will be available 'soon', along with an upgrade kit for the current Ormerod kits.
Ian
RepRapPro tech support
February 04, 2014 12:09PM
droftarts
Ooooh you tease!smiling smiley
Give us a hint on timescale?!?!?!??
Mike
February 04, 2014 01:07PM
I just tried to print a block designed to join 20x20 profile. It has pegs on two sides so no matter how I place it on the platter one of the sets of pegs will be unsupported. This is what happened, the bits jutting out drooped so what can I do to rectify this?
open | download - corner.gif (424.7 KB)
February 04, 2014 01:35PM
I don't think support material will work well for those pegs, so you'll probably need to get a bit creative. You could make it a two part object, or print holes instead of pegs, then push pegs (printed or otherwise) into them. Or, if you don't need the whole thing to be square, put a 45 degree chamfer on the edge of the cube furthest from the pins, and rotate the cube 45 degrees onto that chamfer. The chamfer is just to increase the surface area during printing, to stick the part to the bed.
Ian
February 04, 2014 02:37PM
Or print at 45 degrees as Ian suggests, but on a raft and a thin support wall instead of a chamfer.
Dave
(#106)
