Double Helix Extruder Gears - iamburny Style February 04, 2014 08:36AM |
Re: Double Helix Extruder Gears - iamburny Style February 04, 2014 08:39AM |
Re: Double Helix Extruder Gears - iamburny Style February 04, 2014 08:50AM |
Re: Double Helix Extruder Gears - iamburny Style February 04, 2014 09:01AM |
Re: Double Helix Extruder Gears - iamburny Style February 04, 2014 09:02AM |
Re: Double Helix Extruder Gears - iamburny Style February 04, 2014 09:07AM |
dc42
Thanks, Matt.
May I suggest another part for your upgrade library? It would be useful to have a version of the y-motor bracket that has a hole and nut trap in the back to take the 4mm screw from the Duet enclosure. That way, the Duet box could be slid further along, making more room for fan inlet ducts etc.
Re: Double Helix Extruder Gears - iamburny Style February 04, 2014 09:27AM |
Re: Double Helix Extruder Gears - iamburny Style February 10, 2014 02:43AM |
Re: Double Helix Extruder Gears - iamburny Style February 23, 2014 06:49PM |
Re: Double Helix Extruder Gears - iamburny Style February 23, 2014 09:39PM |
Re: Double Helix Extruder Gears - iamburny Style February 23, 2014 09:51PM |
Re: Double Helix Extruder Gears - iamburny Style April 12, 2014 11:00AM |
Re: Double Helix Extruder Gears - iamburny Style April 12, 2014 11:44AM |
Re: Double Helix Extruder Gears - iamburny Style April 12, 2014 11:51AM |
Re: Double Helix Extruder Gears - iamburny Style April 12, 2014 01:08PM |
michaelljunggren
Hi, and thanks for the gears. They work great... now... But printing these made me aware of something I wasn't previously. For example, the large gear has a profile for the hex screw head, but the exact dimensions turn out incorrect, and the head simply doesn't fit. I believe it's about 1 mm to small and I have to file it up. The print appear to be good otherwise. It's like I missed a setting in both Cura and Slic3r. (I tried both) I made measurements in both the STL and in real life; it's not your model, but my print.
Does anyone have an idea if I made a software configuration error?
Re: Double Helix Extruder Gears - iamburny Style April 12, 2014 02:15PM |
Re: Double Helix Extruder Gears - iamburny Style April 12, 2014 03:52PM |
Re: Double Helix Extruder Gears - iamburny Style April 12, 2014 03:53PM |
Re: Double Helix Extruder Gears - iamburny Style April 12, 2014 04:37PM |
Pointy
I just fitted mine along with Mr Burns extruder block, (the upgraded extruder block has flap to secure the tongue if you need to, and allows you to get the ptfe tube 40mm inside)
On the first test print the motor started stuttering, but after I upped the extruder current to 1amp it's all working beautifully.
Regards,
Les
Re: Double Helix Extruder Gears - iamburny Style April 12, 2014 04:48PM |
Re: Double Helix Extruder Gears - iamburny Style April 12, 2014 05:19PM |
Re: Double Helix Extruder Gears - iamburny Style April 13, 2014 05:26AM |
Re: Double Helix Extruder Gears - iamburny Style April 17, 2014 12:14PM |
Re: Double Helix Extruder Gears - iamburny Style April 20, 2014 04:23PM |
Re: Double Helix Extruder Gears - iamburny Style April 22, 2014 07:28AM |
Re: Double Helix Extruder Gears - iamburny Style December 19, 2015 11:13PM |
Re: Double Helix Extruder Gears - iamburny Style December 20, 2015 12:47AM |
