Hi all,
i think i have a little problem with the bouden extruder hysteresis and i don't know how to deal with it.
I have pinted a litte rotor for a model motor, a disc with a hole inside. The extruder is printing the filament around the hole in the middle with only a small amount of extrution. After that the extruder if printing directly the outer perimeter with much more extrution rate. At that beginning, the extrution is much too less and at the first 1cm there is no perimeter printed in case of the hyteresis and therefore material missing.
Is there a solution or setting to deal with this problem?
In my opinion the extruder should start to extrude a little before printing that outer perimeter to compensate the hystereses.
Any ideas?
Frank
