X axis problem February 04, 2014 03:25PM |
Re: X axis problem February 04, 2014 03:50PM |
Re: X axis problem February 04, 2014 04:15PM |
Re: X axis problem February 05, 2014 03:08PM |
Re: X axis problem February 05, 2014 03:24PM |
Re: X axis problem February 05, 2014 04:24PM |
Re: X axis problem February 06, 2014 01:14AM |
Re: X axis problem February 06, 2014 03:11AM |
Tsessebe
Hi All & greetings from South Africa,
I just finished building my Ormerod (1st 3D printer), and did the Commissioning...
Everything when 100% except that the X axis does not move at all. If I connect the X axis stepper to the Y axis it moves...
I checked and double checked all the connections, I tested the IR sensor and that seems to work, as I get different values as I move the Z Axis Up and down and send the G31 command.
Any help would be much appreciated, I'll be phoning RS South Africa in the morning to hear if the board might have to be replaced.
Regards
Re: X axis problem February 06, 2014 08:02AM |
Re: X axis problem February 06, 2014 09:40AM |
Re: X axis problem February 06, 2014 10:26AM |
Re: X axis problem February 06, 2014 12:45PM |
Re: X axis problem February 06, 2014 12:51PM |
Re: X axis problem February 07, 2014 03:42AM |
droftarts
...... I have to agree that I mostly look at my Ormerod from the side, and regard the side with the bed heater connections as the 'front', though!
Ian RepRapPro tech support
Re: X axis problem February 07, 2014 06:34AM |
Treth
droftarts
Agree! This is why I was also suggesting Tsessebe checks for the correct axis. It could simply be the contacts on the microswitch not making (or using the wrong pins) as someone else reported which could remove a shipping delay and not solve the problem.
Re: X axis problem February 07, 2014 11:15AM |
Re: X axis problem February 14, 2014 12:41PM |
Re: X axis problem [Solved] February 17, 2014 09:09AM |
Re: X axis problem March 05, 2014 02:18PM |
