Terminal block on Duet melted February 04, 2014 03:42PM |
Re: Terminal block on Duet melted February 04, 2014 04:12PM |
Re: Terminal block on Duet melted February 04, 2014 06:40PM |
Re: Terminal block on Duet melted February 05, 2014 03:01AM |
Re: Terminal block on Duet melted February 05, 2014 08:12AM |
Re: Terminal block on Duet melted February 05, 2014 04:14PM |
Re: Terminal block on Duet melted February 06, 2014 02:59AM |
arnaud31
What I did from the word go was to take a piece of main's rigid electric cable (2.5mm2 or 1.5mm2 can't remember), stripped the grey insulation to get the earth and live wires out and used them to connect both boards. It is solid core, no strands, and the wires are not flexible.
No need to twist, less risk of it not being tight and because it is non flexible it doesn't sag and pull out of the terminals.
Re: Terminal block on Duet melted February 08, 2014 08:38AM |
