Bed construction - a word of warning! February 07, 2014 12:42PM |
Re: Bed construction - a word of warning! February 07, 2014 01:01PM |
Re: Bed construction - a word of warning! February 07, 2014 01:09PM |
just thought this is something that should be stressed in the instructions as it's pretty easy to make your plate live and not even realise it!
Re: Bed construction - a word of warning! February 07, 2014 04:52PM |
Re: Bed construction - a word of warning! February 07, 2014 05:49PM |
Re: Bed construction - a word of warning! February 07, 2014 07:13PM |
Re: Bed construction - a word of warning! February 07, 2014 07:47PM |
rm2014
i think it should have been foreseen way before now at the design stage, its called a hazed analysis, professionals use it to analyse their designs before they reach the public domain!
Re: Bed construction - a word of warning! February 07, 2014 08:06PM |
dc42
rm2014
I agree. Putting the plate on the wrong way round is a fairly obvious hazard. I don't understand why RRP didn't make the heated bed pcb symmetrical, then it wouldn't have mattered. Another hazard is having the bed heater terminals exposed at the top of the pcb. Sooner or later, someone (hopefully not me) who is adjusting the bed levelling nuts is going to drop a 5.5mm spanner across them.
Re: Bed construction - a word of warning! February 08, 2014 07:15AM |
Re: Bed construction - a word of warning! February 08, 2014 08:12PM |
bobc
It is generally believed that these type of kits do not fall under CE directives and therefore do not require a mark. The issue is not clear cut, and seems to hinge on the interpretation of "product" meaning "manufactured article", although there is no specific exemption for "kits". The vast majority of products sold are finished articles, so it might be natural to assume that "product" means "finished article". I think it is more likely that where the volume of sales of kits is very low it has not attracted regulation.
For some products that are usually sold as a kit (craft toys, construction, medical), CE directives do apply, and it is clear that the definition of "product" does include kits in some areas. The directives there state that when the kit is used or assembled according to the supplied instructions, the final item or use thereof must conform to the relevant CE directives.
Even if a CE mark is not required, then any product sold in the EU must still confirm to the General Product Safety Directive.
The EU directives are unfortunately a lot of red tape for a small company to go through, but perhaps ultimately if it leads to safer products it is not a bad thing.
Re: Bed construction - a word of warning! February 09, 2014 04:26AM |
Re: Bed construction - a word of warning! February 09, 2014 04:49AM |
Re: Bed construction - a word of warning! February 09, 2014 04:53AM |
Re: Bed construction - a word of warning! February 09, 2014 06:57AM |
Re: Bed construction - a word of warning! February 09, 2014 08:45AM |
Re: Bed construction - a word of warning! February 09, 2014 08:49AM |
Re: Bed construction - a word of warning! February 09, 2014 02:06PM |
Re: Bed construction - a word of warning! February 09, 2014 05:00PM |
Re: Bed construction - a word of warning! February 09, 2014 05:58PM |
Re: Bed construction - a word of warning! February 09, 2014 06:18PM |
Radian
Is everyone happy with the silk screen/solder resist being the only insulator between the heat spreader and the copper traces on the PCB? No doubt it has enough insulation resistance at only 12VDC (so long as it's in good condition). However, with no back EMF suppression we get 50V transients appearing across the heater. I'm not so sure how this might affect things long-term. Another good reason to suppress the transients methinks.
Re: Bed construction - a word of warning! February 09, 2014 07:04PM |
Re: Bed construction - a word of warning! February 09, 2014 07:07PM |
Mickyblueeyes
Hi dc42 the heat spreader in the original design is between the heater pcb and the glass so it is at risk of shorting the tracks of the heater if the solder resist layer breaks down
Re: Bed construction - a word of warning! February 10, 2014 05:01AM |
Re: Bed construction - a word of warning! February 10, 2014 03:22PM |
Re: Bed construction - a word of warning! February 10, 2014 03:35PM |
static65
Just been quoted £110 for a new Duet and IR sensor... huuuuurrrgh.....
Re: Bed construction - a word of warning! February 11, 2014 06:20AM |
