micro switch for Z homing February 09, 2014 06:37AM |
G91 G1 Z5 F200 G90 ; IR probe ; G1 X55 Y0 ; G30 ; G1 Z0 F200 ; microswitch G1 X55 Y35 M558 P0 G92 Z0 G1 Z-100 F200 S1 G92 Z0 G1 Z2 G1 Z-5 F40 S1 G92 Z0 M558 P1
Re: micro switch for Z homing February 09, 2014 08:21AM |
Re: micro switch for Z homing February 12, 2014 01:18PM |
Re: micro switch for Z homing February 12, 2014 02:40PM |
Re: micro switch for Z homing February 12, 2014 04:17PM |
Re: micro switch for Z homing February 12, 2014 04:38PM |
Re: micro switch for Z homing February 12, 2014 05:16PM |
Re: micro switch for Z homing February 13, 2014 04:49AM |
rickity
Andy
Like the idea, the IR probe inconsistency is driving me nutty, 1 question, what are the electrical connections?
regards
Rickity
Re: micro switch for Z homing February 15, 2014 06:25AM |
Re: micro switch for Z homing February 18, 2014 03:39PM |
Re: micro switch for Z homing February 18, 2014 04:03PM |
Re: micro switch for Z homing February 18, 2014 05:40PM |
Re: micro switch for Z homing June 07, 2014 02:45PM |
Re: micro switch for Z homing June 07, 2014 03:50PM |
G91 G1 Z5 F200 G90 G1 X-240 F2000 S1 G92 X0 G1 X3 F200 G1 X-30 S1 G92 X0 G1 X55 F2000 G92 Y0 G1 Y220 F2000 S1 G92 Y200 ; IR probe ; G1 Y0 ; G30 ; G1 Z0 F200 ; microswitch G1 X55 Y35 M558 P0 G92 Z0 G1 Z-100 F200 S1 G92 Z0 G1 Z2 G1 Z-5 F40 S1 G92 Z0 G1 Z0 M558 P1
Re: micro switch for Z homing June 08, 2014 01:20AM |
Re: micro switch for Z homing June 08, 2014 01:45AM |
Re: micro switch for Z homing May 23, 2017 02:45AM |
G91 ; set movement to relative mode G1 Z5 F200 ; move Z up 5mm G90 ; set movement to absolute mode M558 P1 ; set probe to unmodulated mode G1 X-240 F2000 S1 ; home X G92 X0 ; set position to X=0 G1 X3 F200 ; move axis away from X=0 G1 X-5 F200 S1 ; home again, slower G92 X0 ; set position to X=0 G1 X15 F2000 ; ADJUST the X value to put the nozzle on the edge of the bed G92 X0 ; set position to X=0 M558 P2 ; set probe to modulated mode G1 X45 F2000 ; move X, ADJUST the X value to get Z probe over target G92 Y0 ; set position to Y=0 G1 Y-240 F2000 S1 ; home Y G92 Y0 ; set position to Y=0 G1 Y3 F200 ; move Y axis out G1 Y-5 F200 S1 ; home Y, slower G92 Y0 ; set position to Y=0 G1 Y3 F2000 ; ADJUST the Y value to put the nozzle on the edge of the bed G92 Y0 ; set position to Y=0 ;G1 Y0 F2000 ; move Y, ADJUST the Y value to get Z probe over target ;G30 ; home Z, using values from G31 in config.g ;G1 Z5 F200 ; Move Z up to Z=5 G1 X55 Y35 M558 P0 G92 Z0 G1 Z-100 F200 S1 G92 Z0 G1 Z2 G1 Z-5 F40 S1 G92 Z0 M558 P1 ;G1 X0 Y0 F2000 ; Move to X=0 Y=0 ;G1 Z0 F200 ; Move to Z=0
