Sagging MDF, the Q & D fix that anyone can do February 09, 2014 03:42PM |
..and you will have to attach that to the the y-axis-rib and y-axis-cross rib - if you think about it (and if we for the sake of argument say the heat spreader is not needed) what's the difference between what you are trying to achieve compared and the Q & D fix?...beside a lot of added work of drilling holes and the cost of the extra aluminum?
The sagging corners of the mdf bed will hold the aluminum down and fixed on the 3 point T foundation of the supporting ribs, the corner of the mdf will arrest the aluminum in the horizontal direction
Re: Sagging MDF, the Q & D fix that anyone can do February 09, 2014 03:54PM |
Re: Sagging MDF, the Q & D fix that anyone can do February 09, 2014 09:14PM |
Re: Sagging MDF, the Q & D fix that anyone can do February 10, 2014 03:10AM |
Re: Sagging MDF, the Q & D fix that anyone can do February 10, 2014 03:44AM |
Re: Sagging MDF, the Q & D fix that anyone can do February 10, 2014 05:28AM |
Treth
...Your pictures did make me think..... Do you need to cut the MDF? Would you not get the same result with a three point mount as you are now using?...
Re: Sagging MDF, the Q & D fix that anyone can do February 10, 2014 06:17AM |
Re: Sagging MDF, the Q & D fix that anyone can do February 10, 2014 07:00AM |
Re: Sagging MDF, the Q & D fix that anyone can do February 10, 2014 08:44AM |
Re: Sagging MDF, the Q & D fix that anyone can do February 10, 2014 06:03PM |
Re: Sagging MDF, the Q & D fix that anyone can do February 11, 2014 06:03AM |
Re: Sagging MDF, the Q & D fix that anyone can do February 11, 2014 06:51AM |
droftarts
Most other repraps don't use a heat spreader. We've always found it very useful when printing full trays of parts - they stick much better towards the edges with it, otherwise the temperature fall-off towards the edge of the bed can be 5-10C.
Re: Sagging MDF, the Q & D fix that anyone can do February 12, 2014 09:01AM |
Re: Sagging MDF, the Q & D fix that anyone can do February 12, 2014 09:03AM |
appjaws1
Thank you Erik,
I followed your instructions and found this mod very easy to do. I am sure that bed instability has been the root cause of all my problems so I can't thank you enough for a good solution.
I have been thinking about the insulation problem, it strikes me that we need a material that can adjust itself to different thicknesses, my gap ranges from 8mm at the rear to 5mm at the front so something would be more compressed at the front.
I don't know anything about materials especially ones that can stand high temperatures.
I wonder if anybody else has any suggestions?
Thanks again
Paul
Re: Sagging MDF, the Q & D fix that anyone can do February 12, 2014 09:15AM |
Re: Sagging MDF, the Q & D fix that anyone can do May 14, 2014 05:36AM |
dc42
Has anyone tried printing ABS without the heat spreader? I'm thinking that at the higher temperatures, the non-uniform heating might be more important. OTOH the bed takes so long to heat up anyway that perhaps it doesn't matter.
Re: Sagging MDF, the Q & D fix that anyone can do May 14, 2014 08:20AM |
Re: Sagging MDF, the Q & D fix that anyone can do October 25, 2017 11:38AM |
