Re: Replacement Fan Duct/Heatsink Duct - iamburny February 25, 2014 12:17PM |
Re: Replacement Fan Duct/Heatsink Duct - iamburny February 25, 2014 12:44PM |
Re: Replacement Fan Duct/Heatsink Duct - iamburny February 25, 2014 01:06PM |
Re: Replacement Fan Duct/Heatsink Duct - iamburny February 25, 2014 01:07PM |
Re: Replacement Fan Duct/Heatsink Duct - iamburny February 25, 2014 02:06PM |
rayhicks
PS don't these little fans have controllers in them that cater for flyback?
Ray
Re: Replacement Fan Duct/Heatsink Duct - iamburny February 25, 2014 02:45PM |
rayhicks
Yes Dave - I'm talking about the provision on the board for a print cooling fan, not the extruder cooler which is just connected to 12V - the ouputs are labelled "fan0" on the board, they're just next to the extruder, and it's there as a slicer controlled fan (by inserting M106 Sxxx through out the gcode)
Ray
Re: Replacement Fan Duct/Heatsink Duct - iamburny February 25, 2014 04:55PM |
Re: Replacement Fan Duct/Heatsink Duct - iamburny February 26, 2014 07:39AM |
dc42
rayhicks
Ray
I expect they do. The 50V spikes are only a few microseconds long, but I was surprised to see them. The fan current is much less than the heater currents, so I wasn't expecting the wiring inductance to be sufficient to provoke an inductive spike.
Re: Replacement Fan Duct/Heatsink Duct - iamburny February 26, 2014 07:58AM |
dmould
Surely it's the much higher inductance of the fan motor windings rather than the wiring inductance that's the culprit in this case?
dmould
I've not looked into the design of cooling fans, but I see that many have a 3rd wire which I assume outputs a signal from the fan's internal brushless controller with a frequency proportional to the fan speed. I suppose it would be possible to feed that signal back to the Duet and adjust the PWM output to allow the set value to determine the actual fan speed so that all values in the range can be used and the fan is never in a stalled condition at low settings. Probably extreme over-kill, but maybe a fun bit of programming to give really first-class functionality.
Re: Replacement Fan Duct/Heatsink Duct - iamburny February 26, 2014 10:17AM |
dc42
You could be right, but I would expect the inductive spikes to last much longer than 5us if this was the cause.Quote
dmould
speed.
Re: Replacement Fan Duct/Heatsink Duct - iamburny February 28, 2014 06:54AM |
Re: Replacement Fan Duct/Heatsink Duct - iamburny February 28, 2014 07:18AM |
Re: Replacement Fan Duct/Heatsink Duct - iamburny February 28, 2014 07:34AM |
rayhicks
Hi Roberto,
I'm using Frank's first plugin for Cura [forums.reprap.org] (which allows relative extrusions), but with my own settings - I've exported the profile and attached it here (this is from the mac version, but it should import OK in to other versions, use File->Open Profile... to use it I think).[attachment 27611 cura_settings_rh.ini]
It's not easy to find a place for a fan to sit that doesn't obstruct things - initially I thought one could hang off the X carriage at an angle, but it's hard to find a place where it will not catch the extruder when X moves (or worse catch the print!) - I'm going to try using a hose (I've printed some segments that will interlock, to make a hose, but they may not move freely enough - I should be testing them today) - something like a vacuum cleaner hose might work, but they tend to be quiet stiff and springy, the interlocking parts aren't springy, but may be stiff if not smoothed by sanding, which is tedious They leak a little, but seem to be able to deliver the majority of air blown in at one end to the other end, I need to make a fan adapter and a nozzle for mounting near to the hotend to test it fully... this is what the links look like :[attachment 27612 hose.jpg]
Cheers
Ray
Re: Replacement Fan Duct/Heatsink Duct - iamburny February 28, 2014 07:58AM |
Re: Replacement Fan Duct/Heatsink Duct - iamburny February 28, 2014 09:16AM |
