Can someone explain how to avoid this happening February 13, 2014 10:31AM |
Re: Can someone explain how to avoid this happening February 13, 2014 10:42AM |
Re: Can someone explain how to avoid this happening February 13, 2014 10:52AM |
Re: Can someone explain how to avoid this happening February 13, 2014 11:13AM |
Re: Can someone explain how to avoid this happening February 13, 2014 11:27AM |
Re: Can someone explain how to avoid this happening February 13, 2014 11:40AM |
Re: Can someone explain how to avoid this happening February 17, 2014 01:00PM |
Re: Can someone explain how to avoid this happening February 17, 2014 01:51PM |
Re: Can someone explain how to avoid this happening February 17, 2014 02:26PM |
I didn't measure, but I had about a quarter of a can of glue left and topped it up nearly full with acetone, so probably close to 3:1 (acetone:glue). I don't think it matters much - you don't need a lot of plastic remaining after the acetone has evaporated to make the print stick so you can make it very watery. Shake and stir it well after adding the acetone.Quote
dc42
@dmould, what dilution factor do you use when you dilute the solvent cement with acetone?
Re: Can someone explain how to avoid this happening February 17, 2014 05:44PM |
Re: Can someone explain how to avoid this happening February 17, 2014 05:48PM |
Re: Can someone explain how to avoid this happening February 17, 2014 06:56PM |
Re: Can someone explain how to avoid this happening February 17, 2014 07:12PM |
Re: Can someone explain how to avoid this happening February 17, 2014 07:22PM |
Re: Can someone explain how to avoid this happening February 18, 2014 10:44AM |
Re: Can someone explain how to avoid this happening February 18, 2014 11:32AM |
Re: Can someone explain how to avoid this happening February 18, 2014 12:05PM |
