My first mod - new Z axis leadscrew February 16, 2014 06:50PM |
Re: My first mod - new Z axis leadscrew February 16, 2014 08:53PM |
Re: My first mod - new Z axis leadscrew February 17, 2014 05:29AM |
Re: My first mod - new Z axis leadscrew February 17, 2014 05:43AM |
Re: My first mod - new Z axis leadscrew February 17, 2014 06:32AM |
Re: My first mod - new Z axis leadscrew February 17, 2014 12:57PM |
Re: My first mod - new Z axis leadscrew February 17, 2014 01:34PM |
Re: My first mod - new Z axis leadscrew February 17, 2014 01:54PM |
epninety
One thing I think is a glaring omission from probably every 3d printer I've seen is a proper emergency stop button. A reset button inside the box doesn't cut it, nor does a 'pause' button in pronterface that becomes a 'resume' button once clicked
That's probably the next thing I will change. My immediate thought was to mount a button on top of the Z column, but on reflection I want to put the spool holder up there.
Dave
Re: My first mod - new Z axis leadscrew February 17, 2014 02:10PM |
Re: My first mod - new Z axis leadscrew February 19, 2014 08:51AM |
Rest assured - there's precious little of that!Quote
epninety
...or the energy available at switch off...
Dave
Re: My first mod - new Z axis leadscrew February 19, 2014 09:16AM |
Re: My first mod - new Z axis leadscrew March 09, 2014 08:35PM |
Re: My first mod - new Z axis leadscrew March 10, 2014 03:47AM |
Re: My first mod - new Z axis leadscrew March 11, 2014 09:11AM |
Re: My first mod - new Z axis leadscrew March 11, 2014 12:29PM |
Re: My first mod - new Z axis leadscrew March 12, 2014 07:08AM |
, but it seems to run well when I try to turn it with my fingers, can be a problem of the duet board or of the motor?|
Re: My first mod - new Z axis leadscrew March 12, 2014 05:20PM |
Re: My first mod - new Z axis leadscrew March 12, 2014 06:32PM |
Re: My first mod - new Z axis leadscrew March 13, 2014 10:56AM |
Re: My first mod - new Z axis leadscrew March 13, 2014 12:53PM |
raffybuffy
Thank you Epinety!!!!
Very good job :-D
@droftarts Thank you also for the explanation!!!!
So the actual steps for mm is 4000 e with the new threaded rod will be 2133.33 a little less accurate.... :-D
But I presume the more accurate mechanical structure and longevity are more important.
Re: My first mod - new Z axis leadscrew March 13, 2014 01:41PM |
Re: My first mod - new Z axis leadscrew March 14, 2014 03:48AM |
raffybuffy
Re: My first mod - new Z axis leadscrew March 14, 2014 07:00AM |
jy_oc_hx
I'm not sure if raffybuffy is meaning resolution rather than accuracy here. Surely the tolerances on any ormerods manufactured parts would mean there accuracy could be out by 0.03mm at 200mm. (thats only 0.00015%, good enough for me) Even if they are built perfectly
Re: My first mod - new Z axis leadscrew March 17, 2017 01:06PM |
epninety
The STL file is attached. The O-ring to fit is BS1806-213, 23.39mm x 3.53mm
leadscrew_znut_v5_rot.stl
Re: My first mod - new Z axis leadscrew March 17, 2017 02:12PM |
Re: My first mod - new Z axis leadscrew March 17, 2017 07:40PM |
Davek0974
Very rare to see an Ormerod 1 with the original acrylic X-Arm on it - can i suggest an aluminium upgrade maybe
Everyone that has fitted one has reported good improvements, see my sig for details below.
Re: My first mod - new Z axis leadscrew March 17, 2017 08:32PM |
orictosh
Would it be possible to re-design this STL file so that the hole into which the brass nut is 10 mm rather than 8 mm ?
Re: My first mod - new Z axis leadscrew March 18, 2017 04:56AM |
epninety
I don't have the original design files anymore, but this is a trivial change to make directly in the stl file.
e.g. in OpenSCAD...
- import the .stl file.
- move the part around until the hole in centred on one axis.
- draw a 10mm diameter cylinder at the origin.
- rotate the cylinder until it's in the same plane
- subtract one from the other.
- render the resulting object
- export the object to a new stl file.
It probably took me longer to write this message.
Dave
Re: My first mod - new Z axis leadscrew March 20, 2017 01:03PM |
Re: My first mod - new Z axis leadscrew March 21, 2017 06:49AM |
dmould
ormerod168
My first try in OpenScad, seems to work, amazing....
Erik
That's done it! You won't want to design with anything other than OpenScad now!
Dave
