My first mod - new Z axis leadscrew
Posted by epninety
February 16, 2014 06:50PM
I've had my Ormerod up and running for about a month, and despite not making heavy use of it, I was starting to detect ugly warning signs in the Z axis - metal dust, visible wear in the threads, noise etc., so I decided to try fixing it before it broke...
ebay provided a length of 8mm trapezoidal leadscrew and a matching bronze nut for about £30 quid delivered.
I reprinted iamburnys' double helix Z gears, with small mods to accomodate the larger screw size. I sized the centre hole to be the same as the thread root of the leadscrew. Then by gently warming the leadscrew in a gas flame, it was easy to thread the gear straight onto the end of the leadscrew. (Sometimes the low melting point of PLA is an advantage!)
The Z axis nut trap needed serious mods, so after some careful measurements, I drew up a new one from scratch and printed it. Luckily it fitted first time.
The bronze nut has some serious backlash, but that's not too much of a problem for the Z axis where gravity holds the system in tension, as long as everything moves smoothly.
The 'gearing' is now obviously wrong, but the M92 (steps / unit for each axis) command sorts that one out.
I've only tried one print so far - the Single Wall Alignment Test at 50% scale and 0.12mm layer height as iamburny mentioned in his thread and it looks pretty good to me.
It's not finished as yet, only friction stops the cylindrical Z nut from rotating, and I've done nothing about the backlash, but I thought it was a positive start.
Dave
Re: My first mod - new Z axis leadscrew
February 16, 2014 08:53PM
Hi Dave, Nice mod ! that will last you forever . 1kg+ of PLA prints and my M5 rod looks bad, oil turned into black goo very fast. Sagging MDF seems to be a major flaw too. My new M5 brass long nut already on its way ( Thanks Treth ! ).
February 17, 2014 05:29AM
looking good epninety,
if you're worried about the backlash (but I don't think you should be for Z since as you pointed out it's preloaded by the weight of the X axis boom and only the upper surface of the thread is used), you could use (a little more) heat to thermoform a thread in an acetal/delrin nut like this [bbs.homeshopmachinist.net].
To prevent the cylindrical nut from rotating (more of a problem), you could file one or more flats on it, and modify your trap to hold against the flat/s, or you could drill down though the top of the nut trap into the top of the nut to form a dimple, then use a self tapping screw through the plastic and into the dimple to hold it still,
Ray
February 17, 2014 05:43AM
epninety
I have a concern that you have locked the Z nut in top and bottom. The danger is if you drive the Z too low it will force the hot end into the table. With the existing design the nut pops out the bottom and there is no damage done. Apart from that I like it, can you tell me the eBay vendor you bought your rod and nut.
John
February 17, 2014 06:32AM
Thanks for the positive comments and ideas smiling smiley
My original plan was to retain the nut with one or more M3 screws tapped into the upper face, running down the Z axis. But when I was measuring and sketching for the new mount I realised I'd prefer the Z nut to be able to move around alittle to ensure the best possible alignment. That could still be done with oversized holes, but I have what I think is a prettier plan... I will move the mounting flanges apart slightly, and groove them to take a couple of O rings to take up the gap. I think that will allow enough freedom to set the alignment and accomodate the inevitable eccentricity, but provide enough resistance that the Z nut won't rotate.
If that doesnt work, then it's time for machined flats or locking screws, or probably just a blob of RTV silicone to persuade it to stay put.
Leadscrew and nut came from these guys
You are right of course, about the danger of crashing the tool into the table - it's a risk I've always lived with in my CNC'd Peatol mill, so I guess I'm more relaxed about it than many. It would be easy to mill flats or a hex into the nut and retain it only at the top, which might solve both problems at once.
EDIT : Forgot to say, only retaining the nut at the top would make assembly much easier too spinning smiley sticking its tongue out
One thing I think is a glaring omission from probably every 3d printer I've seen is a proper emergency stop button. A reset button inside the box doesn't cut it, nor does a 'pause' button in pronterface that becomes a 'resume' button once clicked eye popping smiley
That's probably the next thing I will change. My immediate thought was to mount a button on top of the Z column, but on reflection I want to put the spool holder up there.
Probably not much playtime before next weekend now, but I'll probably have changed the whole plan again by then...
Dave
Edited 1 time(s). Last edit at 02/17/2014 06:36AM by epninety.
February 17, 2014 12:57PM
Very Nice!
Lovely work Dave, and a fantastic resulting print, did you have any trouble centering the threaded rod in the Z-gear?
like the blue too winking smiley
Matt
Limited Edition Red RS Ormerod 1 #144 of 200 - RRP 1.09fw
iamburnys Ormerod Upgrades Github
Follow me on ThingiVerse My Designs
February 17, 2014 01:34PM
Thanks Matt smileys with beer
No problem centering it - the original M5 nut is 8mm across the flats, so it serves as a handy guide to get the screw initially started.
I modified your gear design to reduce the depth of the hex hole (to get maximum thread engagement), and opened the centre borehole out to 7mm (the root thread size). I'd open it out to 7.5mm next time so the melted plastic has somewhere to go. It pretty much screwed on straight away, then before it cooled too much I backed the Z nut up against it to keep it straight. I think the key is to use the least heat possible to get the job done, so things don't get too floppy.
It has a very slight wobble, but no worse than I had with the original setup, and of course that could be improved with a little gentle attention from a small blowtorch.
The best bit of course, is that if it all goes wrong... just print another one spinning smiley sticking its tongue out
Dave
February 17, 2014 01:54PM
epninety
Dave
The mains switch on the 12V PSU acts as a pretty good emergency stop ... You could feed the PSU via a relay controlled with a traditional red mushroom button.
Dave
(#106)
February 17, 2014 02:10PM
Thinking along similar lines ... The PS_ON# signal on the PSU loom is pulled low (to ground) to turn the PSU on, and pulled high (to 3.3V) internally in the PSU. There's no particular spec on the response time, or the energy available at switch off, but it should be adequate for an e-stop. Maybe time for an experiment this evening...
Dave
February 19, 2014 08:51AM
epninety
...or the energy available at switch off...
Dave
Rest assured - there's precious little of that!
From what I've seen with the Alpine PSU, even with both heaters off, the reservoir caps barely hold up for a missing mains cycle. With the bed heater on, it's down within a millisecond or two.
I've not looked at the PS_ON# response but it's almost certainly equivalent to disconnecting the mains supply.
RS Components Reprap Ormerod No. 481
February 19, 2014 09:16AM
I think that's exactly right - the ATX spec calls for a hold up time of 16ms, almost a whole cycle at 60Hz smiling smiley
I'll lash something up at the weekend and see what happens.
March 09, 2014 08:35PM
Another update just to keep the info in one thread...
johneato commented the Z nut was fully captive and that might cause problems if the Z axis crashed the bed. At the same time, I was looking for a better way to retain the Z nut while allowing for misalignment.
So my next design of Z nut bracket centres the Z nut in an O-ring that happily fits the 45degree bevel on the lead nut. It (the O -ring) is retained on the Z bracket with a couple of drops of superglue. Only gravity and friction holds the lead nut, preventing rotation and keeping it centred.
Seems to work nicely, I completed a couple of prints this evening without issue. You can see from the pen mark it hasn't rotated through the print.
It's still not fully safe, the Z nut is too large to pass the stepper motor in the event it makes a bid for freedom, but at least there is a small safety margin if it all goes wrong. With luck it will spin freely with the shaft once the load is off, but I'm not about to try it.
Dave
Edited 1 time(s). Last edit at 03/09/2014 08:36PM by epninety.
March 10, 2014 03:47AM
epninety
Much happier with your new design
John
March 11, 2014 09:11AM
Very interesting work, I'm worried about the quality of movement on z axis and was thinking to do something.
But the pitch of z axis is 1.5mm? there is a way to use another pitch setting something?
smileys with beer
March 11, 2014 12:29PM
M92 command sets number of steps per axis, so send M92 Z2133 sets everything back to working correctly.
It's not a perfect integer, should be 2133.333recurring, but the error is only 0.03% so lost in the noise.
Dave
March 12, 2014 07:08AM
Tank you Dave,
smileys with beer
I have ordered the Z nut and the leadscrew I hope to gain in precision and reliably.
The default leadscrew pitch is 1.5mm?
I'll find this site for steps calculation seem's to be usefully...
Can you post your .stl of z-bracket?
I've got some problem with Z-Axis (as soon as I've ordered the new z rod and nut) occasionally the z-axis threaded rod seems to get stuck and i hear "stumph, stumph, stumph"confused smiley, but it seems to run well when I try to turn it with my fingers, can be a problem of the duet board or of the motor?
Edited 1 time(s). Last edit at 03/12/2014 07:10AM by raffybuffy.
March 12, 2014 05:20PM
The STL file is attached. The O-ring to fit is BS1806-213, 23.39mm x 3.53mm
open | download - leadscrew_znut_v5_rot.stl (136.9 KB)
March 12, 2014 06:32PM
@raffybuffy
The standard leadscrew pitch is 0.8mm, which is the usual thread pitch for M5 thread. Which is why the standard steps per mm is 4000:
(motor steps per revolution x microsteps) / thread pitch = (200 x 16) / 0.8 = 4000
Ian
RepRapPro tech support
March 13, 2014 10:56AM
Thank you Epinety!!!!
Very good job :-D
@droftarts Thank you also for the explanation!!!!
So the actual steps for mm is 4000 e with the new threaded rod will be 2133.33 a little less accurate.... :-D
But I presume the more accurate mechanical structure and longevity are more important.
March 13, 2014 12:53PM
raffybuffy
Very good job :-D
If you print something that is 200mm high, it will be too short by just over 0.03mm, so the overall inaccuracy is insignificant.
The only thing you may find is that your prints have a bit of vertical banding unless you deliberately choose a layer thickness that is an exact multiple of 1/2133 mm, because otherwise the firmware will have to make some layers 1 step greater or fewer than other layers so as to get the correct average layer thickness.
Dave
(#106)
March 13, 2014 01:41PM
dmould
..it will be too short by just over 0.03mm, so the overall inaccuracy is insignificant...
Dave
(#106)
could be a tiny bit more, afaik the pitch of a treaded rod is defined in the horizontal position :-)
Erik
March 14, 2014 03:48AM
raffybuffy
I'm not sure if raffybuffy is meaning resolution rather than accuracy here. Surely the tolerances on any ormerods manufactured parts would mean there accuracy could be out by 0.03mm at 200mm. (thats only 0.00015%, good enough for me) Even if they are built perfectly
March 14, 2014 07:00AM
jy_oc_hx
I am not so staid, smiling smiley
I just want to say that changing the treated rod, you will not have any disadvantage otherwise the theorical ones!!!! smiling smiley
I have ordered the treated rod and nut because I don't like the original, I think is too poor and I notice that the nut is not stable on the rod, and the rod itself is already worn... and really it look bad!!!! smiling smiley
March 17, 2017 01:06PM
epninety
Would it be possible to re-design this STL file so that the hole into which the brass nut is 10 mm rather than 8 mm ?
I have linked to this message and to the file from my site [www.3dprintandstuff.co.uk]
As I found this part useful and straight forward to mount a lead screw.
Many Thanks
Chris Hills
Edited 1 time(s). Last edit at 03/17/2017 01:07PM by orictosh.
Supporting 3D Printers with Parts and Build services.
Printer: Ormerod 2 (528.4) Duel extruder set-up with Aluminium X-Rib, RRPro Firmware v1.11-ch (2016-04-08)
March 17, 2017 02:12PM
Very rare to see an Ormerod 1 with the original acrylic X-Arm on it - can i suggest an aluminium upgrade maybe winking smiley
Everyone that has fitted one has reported good improvements, see my sig for details below.
Another RS Ormerod Mk1 meets the world smiling smiley
Retired now but I used to make....
CNC Machined Mk1 aluminium bed support plates for the Ormerod
CNC machined X-plates and ribs for Mk1 & Mk2 Ormerods
CNC machined bed support arms for the Mk2 Ormerod.
Dual Hot-End heatsink blocks.
March 17, 2017 07:40PM
Davek0974
You need to check the clock Davek! Those pics were posted more than 3 years ago!
(And I don't believe I reported a good improvement after fitting one of your arms.)
Edited 1 time(s). Last edit at 03/17/2017 07:47PM by epninety.
March 17, 2017 08:32PM
orictosh
Hi Chris
I don't have the original design files anymore, but this is a trivial change to make directly in the stl file.
e.g. in OpenSCAD...
- import the .stl file.
- move the part around until the hole in centred on one axis.
- draw a 10mm diameter cylinder at the origin.
- rotate the cylinder until it's in the same plane
- subtract one from the other.
- render the resulting object
- export the object to a new stl file.
It probably took me longer to write this message.
Dave
March 18, 2017 04:56AM
epninety
e.g. in OpenSCAD...
Dave
My first try in OpenScad, seems to work, amazing....
leadscrew_10_znut_v5_rot.zip
Erik
Edited 1 time(s). Last edit at 03/18/2017 05:03AM by ormerod168.
March 20, 2017 01:03PM
ormerod168
Erik
That's done it! You won't want to design with anything other than OpenScad now!
Dave
March 21, 2017 06:49AM
dmould
ormerod168
Erik
Dave
That's an easy choice, I have no knowledge of 3D modeling programs whatsoever!
...but I like this - I like this a lot!
Erik
