Extruder wear February 17, 2014 04:51PM |
Re: Extruder wear February 17, 2014 05:00PM |
Re: Extruder wear February 17, 2014 06:17PM |
Re: Extruder wear February 17, 2014 06:38PM |
Re: Extruder wear February 17, 2014 06:55PM |
Re: Extruder wear February 17, 2014 07:45PM |
Re: Extruder wear February 17, 2014 08:17PM |
Re: Extruder wear February 17, 2014 08:52PM |
Re: Extruder wear February 18, 2014 04:27AM |
Re: Extruder wear February 18, 2014 04:57AM |
Radian
Thanks for the heads-up! I'm wondering how freely your filament comes off the spool though... what kind of reel support do you use?
Re: Extruder wear February 18, 2014 05:28AM |
Re: Extruder wear February 18, 2014 06:47AM |
Re: Extruder wear February 18, 2014 07:14AM |
Re: Extruder wear February 18, 2014 12:39PM |
Re: Extruder wear February 18, 2014 07:00PM |
Re: Extruder wear February 18, 2014 11:05PM |
Re: Extruder wear February 19, 2014 01:20AM |
Re: Extruder wear February 19, 2014 07:04AM |
Re: Extruder wear February 19, 2014 12:05PM |
Re: Extruder wear February 20, 2014 08:04PM |
dmould
I'm not sure it is going to do any harm when it does completely break through. I see no reason to have any guide on the part - surely the filament could be fed directly from the spool to the hobbed insert?
Re: Extruder wear February 21, 2014 04:27AM |
Re: Extruder wear February 21, 2014 09:19AM |
Re: Extruder wear February 21, 2014 09:47AM |
Re: Extruder wear February 21, 2014 11:58AM |
I don't see how, given that the distance changes so much with X position. A Bowden rotary drive could be used I suppose (like a car's speedo cable or flexible drill drives), but that will almost certainly have more backlash than the push-pull filament. The only other way I can think of would be an arrangement of arms and pulleys like an old-fashioned dentist's drill, but again there would be lots of backlash in that.Quote
Mickyblueeyes
Hi, putting the extruder on the hot end might be possible for the single extruder version but when we want to use 2 or 3 extruders it's going to get very heavy, I was wondering if some sort of flexible drive could be used between the motors mounted on the arm and the hobbed end mounted on the extruder.
Re: Extruder wear February 21, 2014 01:42PM |
Re: Extruder wear February 21, 2014 02:09PM |
Re: Extruder wear February 21, 2014 02:25PM |
