z-height sensor 'top hat' light shield with improved target proposal February 21, 2014 03:23AM |
Radian
@Treth - I understand what you mean about waiting before publishing. If you do get round to it though, I hope you put some photos in your topic.
Re: z-height sensor 'top hat' light shield with improved target proposal February 21, 2014 04:21AM |
Re: z-height sensor 'top hat' light shield with improved target proposal February 21, 2014 08:41AM |
Re: z-height sensor 'top hat' light shield with improved target proposal February 22, 2014 06:34AM |
Re: z-height sensor 'top hat' light shield with improved target proposal February 22, 2014 07:44AM |
Radian
Treth, how steady are your G31 readings if you repeatedly issue them in quick succession? I always see a spread of up to 7 counts.
Re: z-height sensor 'top hat' light shield with improved target proposal February 22, 2014 03:47PM |
Hi Radian and DC42,Quote
dc42
Radian
If you are powering the Duet from the 12V supply via the switching regulator, then the connections between the sensor board and the Duet pick up noise from the regulator. See [forums.reprap.org].
Re: z-height sensor 'top hat' light shield with improved target proposal February 22, 2014 04:29PM |
Re: z-height sensor 'top hat' light shield with improved target proposal February 22, 2014 04:33PM |
Re: z-height sensor 'top hat' light shield with improved target proposal February 22, 2014 04:55PM |
Re: z-height sensor 'top hat' light shield with improved target proposal February 22, 2014 04:57PM |
Re: z-height sensor 'top hat' light shield with improved target proposal February 22, 2014 05:27PM |
Re: z-height sensor 'top hat' light shield with improved target proposal February 22, 2014 05:31PM |
Hi Ray, I did the best I could here and turned off all tungsten lights and only left on some CFLs (wall lights) in an adjoining room.Quote
rayhicks
Hi Treth,
it looks like a pretty significant increase in standard deviation - it would be interesting to see zero-signal versions too (ie with light-proof paper over the photodetector), to show electronic noise isolated from optical signal variation (although you'd probably only see one side of the distribution providing there's no offset). [edit - it would be interesting to see if rerouting the signal as dc42 did also works for you with the external power and load connected)[edit]
Ray
Re: z-height sensor 'top hat' light shield with improved target proposal February 22, 2014 05:42PM |
I was very lucky with the weather and sunrise for these two days (which was shining at a low angle on the z axis just above the x axis, so close to the sensor for direct light and certainly bright in that vicinity at the peaks seen).Quote
rayhicks
Looks like a good belt to use before dc42 produces his braces - the combination of both should be synergistic. It's quite astonishing to see the level go up to >900 on more than one occasion (hard to do a fully controlled run with sunlight being a variable, and I presume you used just room light for the previous figures since you posted in the evening - will you have time to repeat with hats off and on tomorrow morning?)
Cheers
Ray
Re: z-height sensor 'top hat' light shield with improved target proposal February 22, 2014 06:46PM |
Re: z-height sensor 'top hat' light shield with improved target proposal February 23, 2014 12:14AM |
Re: z-height sensor 'top hat' light shield with improved target proposal February 23, 2014 06:00AM |
Re: z-height sensor 'top hat' light shield with improved target proposal February 23, 2014 06:20AM |
KimBrown
then a Pic could be used to do the calculation, and also take a quick burst of readings that it could average out.
Re: z-height sensor 'top hat' light shield with improved target proposal February 23, 2014 06:49AM |
Re: z-height sensor 'top hat' light shield with improved target proposal February 23, 2014 09:48AM |
