Printing Wood!!!
Posted by johneato
Printing Wood!!!
February 21, 2014 05:30AM
Anybody tried this product.
[www.creativetools.se]
This could be very useful. A bit pricey at £22 for .25Kg but for that special job could be great
John
Re: Printing Wood!!!
February 21, 2014 05:37AM
This is another i'd like to try apparently it even smells like wood!, not so pricey either.
[colorfabb.com]
Matt
Edited 1 time(s). Last edit at 02/21/2014 05:41AM by iamburny.
Limited Edition Red RS Ormerod 1 #144 of 200 - RRP 1.09fw
iamburnys Ormerod Upgrades Github
Follow me on ThingiVerse My Designs
February 21, 2014 05:39AM
Hi John,
I did some test with LAYWOO-D3 and it works w/o problems. You have to watch the temperature - low temperature means brighter, higher temperature darker wood. In any case you have to look a the extrusion parameters.
I'm currently building an DIY extruder and hope to produce the material much cheaper this way.
Markus
XBee & electronics blog: [lookmanowire.blogspot.com]
February 21, 2014 07:00AM
Just what I wood (he) need to make my EUR Pallet prints look more natural, btw, pallets is great for bridge-building tests
EUR Pallets in scale 1:10, 1:20, 1:40, 1:80 (and a Chep Pallet in between)
Erik
February 21, 2014 03:34PM
ormerod168
[attachment 27227 EUR-Pallet1.jpg]
[attachment 27228 EUR-Pallet2.jpg]
Erik
very nice! would you be able to show the underside of the prints, where the bridge was laid? I am curious to see how it looks.
February 21, 2014 04:04PM
Very creative.
manually change the G-files in order to change the extruder temperature which manipulates the color :-)
February 21, 2014 06:45PM
THIS LOOK AMAZING!
in even more of a hurry to get me ormerod working now! >.<
February 22, 2014 02:07AM
ormerod168
Erik
yes please, how do you print those bridges?
February 22, 2014 06:34PM
arnaud31
..very nice! would you be able to show the underside of the prints, where the bridge was laid? I am curious to see how it looks.
The pallets was printed upside down, so all the pictures is as seen from underneath as printed - taking photos is really not my thing, I'm a "auto settings using - no time to read documentation man", but I think these pictures came out rather nicely, the problem with macro photography is the lens always seems to get in the way of the lighting from the flash, the flash should be placed around the lens rather than on top me think - but then I got the bright (!) idea of taking the pictures inside a flat white box
I placed a 0.177 (4.5mm) diabole airgun pellet to set the scale
Edit: added picture
Erik
Edited 1 time(s). Last edit at 02/22/2014 08:10PM by ormerod168.
February 22, 2014 06:54PM
That really is quite impressive bridging, in fact the largest palette seems to have smoother undersides that the smallest in one of the photos! Do you turn the Ormerod upside down to print these? grinning smiley
Ray
February 22, 2014 07:35PM
SlinBin
Nothing to it at all - anyone can do it - anyone! - how do I know? - because I'm anyone, I don't know anything about 3-D printing whatsoever and yet I printed this thing, just use your sense of logic, surely you will have to get your extrusion right, you don't wan't to extrude too much or too little, experiment, get it right and watch that spider do it's thing, it's quite fascinating...
Erik
February 22, 2014 11:49PM
Hi Erik, I like the pallets. Have you the stl files? I could do with making some pallets to scatter around my ON30 layout.
February 23, 2014 05:38AM
KimBrown
Hi Kim, here's the file, just scale it in slic3er:
[www.thingiverse.com]
Here's another one I tried to print, did no go so well, memo to myself: look at the stI before printing, and do not print pallet standing on end he he...
Erik
February 23, 2014 10:15AM
Thanks Erik, you know it shows how Observant I am when I'm tired.... I never noticed the scale in Slic3r till you said.
I can see me making allot of pallets soon..... spinning smiley sticking its tongue out
I'd like to use that wood filament, but I think the price will cut me out for the moment...
In any case. The printer is now sat waiting for me in the car, as I got that fed up with the floppy table, and wandering Z axis.
BUT when I get home on Wednesday I'll start correcting that in a big way....
Only two more days at work.....hot smiley
March 02, 2014 07:57PM
That colorFabb woodfill is actually quite different than laywood. It doesn't do the color changing thing and has better mechanical properties. So, depending on what your goal is with the material, it may be better or worse.
It also bridges amazingly well.
Here is my initial review on it from a few months back. [www.printedsolid.com]
Since that time, I've gotten a better handle on printing it without nozzle clogs. I was running it at too small layer thicknesses and was leaving the filament hot in the nozzle. Now I flush it with some PLA after every print and I'm good.
If you happen to be reading this from the US and just want to try a little bit without spending the $$ for a full spool, we've got sample packs at printedsolid.com in 3mm and 1.75 for $12 with free shipping.
March 03, 2014 04:43AM
Looks very interesting. Is there a particular grain direction? Or are the fibres random?
I'm thinking that if filaments with a grain ( not sure of the correct term-- fibrous filaments?) are introduced then there will have to be new software so that you can specify more precisely how you want the grain to run!
regards
Andy
Ormerod #318
www.zoomworks.org - Free and Open Source Stuff smiling smiley
May 08, 2014 07:05PM
markbee
Markus
@markbee Hi! what nozzle size are you using with laywood-D3? did you had any clogging issue due to carbonisation of the wood?
Mine is from FormFutura. I did not printed it yet, because I have a 0.35 nozzle and I feel a little bit at risk...
thank you in advance!
Disclaimer: io ce la metto tutta a darti consigli sensati, sta a te non incendiare nulla :-)
CoreXY HyperCube. [www.thingiverse.com] | Cerchi test? Make: test set: [www.thingiverse.com]
