New firmware February 24, 2014 10:12AM |
Re: New firmware February 24, 2014 10:38AM |
Re: New firmware February 24, 2014 04:09PM |
Re: New firmware February 24, 2014 06:52PM |
Re: New firmware February 24, 2014 07:02PM |
Re: New firmware February 24, 2014 07:10PM |
Re: New firmware February 24, 2014 07:22PM |
Re: New firmware February 24, 2014 07:43PM |
Re: New firmware February 24, 2014 07:47PM |
Re: New firmware February 24, 2014 08:53PM |
Re: New firmware February 25, 2014 03:17AM |
KimBrown
David, I think (? My printer is in the car, so I can't check), that 57a (the firmware I'm using) has that problem as well.
I think it happend to me a couple of times when I was messing around doing the Red Glass tests.
KimBrown
Also I found zeroing the Z axis in a position that wasn't the normal position for homing the Head (I started doing it at x=100)
would accept the 0.1mm reading I put in, but when I checked the position of the Head via Pronterface (with out moving it)
it would report a different reading to the 0.1mm. It took me a few minutes to twig on what was going on, but
it was the bed leveling compensation that was throwing the Z reading out.
Re: New firmware February 25, 2014 07:19AM |
Re: New firmware February 25, 2014 02:52PM |
Re: New firmware February 25, 2014 02:59PM |
Re: New firmware February 25, 2014 03:29PM |
dc42
I've just added revision 057q-dc42 here [github.com]. The only change is to make the M106 fan control command work properly, and to add an optional P parameter to allow the PWM range to be set to a value other than 0.0 to 1.0, e.g. 0 to 255 for compatibility with slic3r and Cura. The value of this parameter is not currently stored in non-volatile memory, but could be if users want that.
Re: New firmware February 25, 2014 03:36PM |
Re: New firmware February 25, 2014 04:01PM |
Re: New firmware February 25, 2014 04:35PM |
Re: New firmware February 25, 2014 08:01PM |
more than enough to put me in the list!|
Re: New firmware February 26, 2014 11:05AM |
Re: New firmware February 26, 2014 11:09AM |
Re: New firmware February 26, 2014 11:20AM |
Re: New firmware February 26, 2014 11:21AM |
Re: New firmware February 26, 2014 12:19PM |
@echo off title RepRapPro Ormerod Flash Utility echo. set /p ComPort= Enter COM port for Duet (as 'COMx'): echo. echo Please press the 'ERASE' button, echo then the 'RESET' button and wait echo at least 10 seconds then: echo. pause echo. bossac --port=%ComPort% -U true -e -w -v -b %1 -R echo. pause
Re: New firmware February 26, 2014 12:48PM |
Re: New firmware February 26, 2014 01:17PM |
Re: New firmware February 28, 2014 12:11PM |
Re: New firmware February 28, 2014 12:31PM |
Re: New firmware February 28, 2014 01:21PM |
Re: New firmware February 28, 2014 02:33PM |
