Re: New firmware February 28, 2014 07:15PM |
Re: New firmware February 28, 2014 07:37PM |
Re: New firmware February 28, 2014 07:41PM |
rayhicks
I think once you've set "home", X and Y won't move negative (there's a small allowance for Z)- they also won't move past the end of the plate - this was a feature requested by more than one person and saves a lot of belt grinding - I was surprised the first time I hit +100 [edit when I meant -100] on Y and it stopped without grinding! and thankful too. If you NEED to get past the restriction, turn off the motors (M18 I think, but I use a button in the host software I use) then you can move the X/Y manually to a "negative" point.
Ray
Re: New firmware February 28, 2014 08:02PM |
Re: New firmware March 01, 2014 02:47AM |
Re: New firmware March 01, 2014 03:23AM |
Flyskyhy
Do you know if there is a way that I can reposition the Y zero point (or, equivalently, that the Y end-switch is defined to be at a different Y value)? That would move my Z-home position within Y range again.
Re: New firmware March 01, 2014 03:55AM |
to mean that this is more of an offset adjustement. what is correct?Quote
dc42
if your Y axis will currently travel from -5 to +200, then sending M208 Y5 will define the range as 0 to 205.
Re: New firmware March 01, 2014 05:41AM |
Re: New firmware March 02, 2014 05:05AM |
Re: New firmware March 02, 2014 08:28AM |
Re: New firmware March 02, 2014 08:55AM |
Re: New firmware March 02, 2014 11:02AM |
Re: New firmware March 02, 2014 11:34AM |
Re: New firmware March 02, 2014 12:11PM |
Re: New firmware March 02, 2014 04:33PM |
Re: New firmware March 02, 2014 06:41PM |
Re: New firmware March 02, 2014 06:52PM |
Re: New firmware March 03, 2014 05:12AM |
Re: New firmware March 03, 2014 05:46AM |
Re: New firmware March 04, 2014 09:40AM |
dc42
3. Added additional optional Z probe parameters: calibration temperature, and temperature coefficient of height. Example: G31 Z0.8 P600 T60 C0.0076. If you do not specify a T value, then the current bed temperature will be assumed unless the G31 command is being processed from a file.
dc42
4. Z-probe parameters, Z-probe type, emulation mode and network IP addresses are now saved to flash memory so that they survive power-off and reset cycles. Note that whenever you load new firmware, the flash memory gets erased and all these parameters get reset to default values. Values read from config.g override the saved values.
Re: New firmware March 04, 2014 09:59AM |
Re: New firmware March 04, 2014 05:07PM |
Re: New firmware March 05, 2014 06:04AM |
Re: New firmware March 05, 2014 06:17AM |
Re: New firmware March 05, 2014 06:49AM |
Re: New firmware March 05, 2014 08:23AM |
Re: New firmware March 05, 2014 10:49AM |
Re: New firmware March 05, 2014 03:59PM |
Re: New firmware March 05, 2014 04:20PM |
Re: New firmware March 05, 2014 04:24PM |
