Extruder Pull back the Filament very long when its Printing February 24, 2014 12:24PM |
Re: Extruder Pull back the Filament very long when its Printing February 24, 2014 12:54PM |
Re: Extruder Pull back the Filament very long when its Printing February 24, 2014 02:56PM |
Re: Extruder Pull back the Filament very long when its Printing February 24, 2014 05:12PM |
; generated by Slic3r 1.0.0RC3 on 2014-02-24 at 17:26:41 ; layer_height = 0.2 ; perimeters = 2 ; top_solid_layers = 5 ; bottom_solid_layers = 5 ; fill_density = 0.25 ; perimeter_speed = 100 ; infill_speed = 100 ; travel_speed = 100 ; nozzle_diameter = 0.5 ; filament_diameter = 1.75 ; extrusion_multiplier = 0.9 ; perimeters extrusion width = 0.50mm ; infill extrusion width = 1.02mm ; solid infill extrusion width = 0.85mm ; top infill extrusion width = 0.85mm G21 ; set units to millimeters G1 Z5 F5000 ; lift nozzle G90 ; use absolute coordinates M83 ; use relative distances for extrusion G1 F2400.000 E-4.00000 G1 Z0.400 F6000.000 G1 X86.300 Y86.110 F6000.000 G1 E4.00000 F2400.000 G1 X86.990 Y85.460 E0.07094 F3000.000 G1 X87.500 Y85.020 E0.05041 G1 X88.390 Y84.320 E0.08474 G1 X88.590 Y84.210 E0.01708 G1 X88.570 Y84.190 E0.00212 G1 X88.950 Y83.920 E0.03488 G1 X89.670 Y83.460 E0.06394 G1 X90.740 Y82.830 E0.09292
Re: Extruder Pull back the Filament very long when its Printing February 24, 2014 07:19PM |
Re: Extruder Pull back the Filament very long when its Printing February 26, 2014 05:25AM |
Re: Extruder Pull back the Filament very long when its Printing February 26, 2014 07:26AM |
Don't put it in the config file. I can't remember the exact explanation but i do remember it being a definate point.Quote
Blitza
Like this gear here, and how i should write in the config from the sd Card that the Printer Level the bed automatic, could somebody Show me examples please.
Thank you for your help Guys
Re: Extruder Pull back the Filament very long when its Printing February 26, 2014 09:58AM |
Re: Extruder Pull back the Filament very long when its Printing March 01, 2014 09:39AM |
