Re: "I think! I might have found the ultimate Sub-Bed for the HotBed (Bigger than a maybe)" March 01, 2014 09:37AM |
Re: "I think! I might have found the ultimate Sub-Bed for the HotBed (Bigger than a maybe)" March 01, 2014 10:45AM |
Re: "I think! I might have found the ultimate Sub-Bed for the HotBed (Bigger than a maybe)" March 01, 2014 01:48PM |
Mickyblueeyes
Hi Ormerod168 I have done a similar job with the aluminium endplates with the acrylic inside I also lengthened them and made the distance between the bars greater to make the table more stable.
regards
Mike
Re: "I think! I might have found the ultimate Sub-Bed for the HotBed (Bigger than a maybe)" March 01, 2014 01:55PM |
Radian
Hi Erik, glad to see Octo still has his job
Re: "I think! I might have found the ultimate Sub-Bed for the HotBed (Bigger than a maybe)" March 01, 2014 02:27PM |
Re: "I think! I might have found the ultimate Sub-Bed for the HotBed (Bigger than a maybe)" March 01, 2014 02:45PM |
KimBrown
Success... at the 4th attempt it printed. It's made alot of difference.
I think that the acrilic end plates need redesigning to bolt directly on to the Ally profile thou...
Re: "I think! I might have found the ultimate Sub-Bed for the HotBed (Bigger than a maybe)" March 14, 2014 07:04AM |
Re: "I think! I might have found the ultimate Sub-Bed for the HotBed (Bigger than a maybe)" March 14, 2014 12:32PM |
Re: "I think! I might have found the ultimate Sub-Bed for the HotBed (Bigger than a maybe)" March 14, 2014 03:03PM |
Re: "I think! I might have found the ultimate Sub-Bed for the HotBed (Bigger than a maybe)" March 14, 2014 04:18PM |
Re: "I think! I might have found the ultimate Sub-Bed for the HotBed (Bigger than a maybe)" March 14, 2014 04:53PM |
KimBrown
Hi Balidey, I cheated with my composite board....
.....I then mounted the original MDF board, and put the Composite board on top so as to retain the three alignment holes where it fits the frame.
It saved me having to worry about being real careful at cutting the alignment holes out and added a little more stiffness.
Re: "I think! I might have found the ultimate Sub-Bed for the HotBed (Bigger than a maybe)" March 15, 2014 08:20AM |
Re: "I think! I might have found the ultimate Sub-Bed for the HotBed (Bigger than a maybe)" March 17, 2014 08:20AM |
Re: "I think! I might have found the ultimate Sub-Bed for the HotBed (Bigger than a maybe)" March 17, 2014 09:02AM |
Re: "I think! I might have found the ultimate Sub-Bed for the HotBed (Bigger than a maybe)" March 17, 2014 09:15AM |
Re: "I think! I might have found the ultimate Sub-Bed for the HotBed (Bigger than a maybe)" March 17, 2014 03:56PM |
Re: "I think! I might have found the ultimate Sub-Bed for the HotBed (Bigger than a maybe)" March 18, 2014 04:25AM |
Re: "I think! I might have found the ultimate Sub-Bed for the HotBed (Bigger than a maybe)" March 18, 2014 06:04AM |
- one concern with having a double thickness of 3mm glass between heat source and print is it might slow down heat transfer, though this could be remedied by increasing the temperature a little. It'd be preferable to use a neutral cure silicone filler (or a two-part silicone) rather than the standard vinegar-producing DIY stuff in contact with the PCB to prevent corrosion. PCB laminate can be quite curved and hard to find in large areas - it might be easier using some tufnol (available in the same composites as PCB backing, but manufactured for mechanical fabrication so more likely to be flat, and avaialble oin 4 by 8 sheets!), or even another layer of glass (though this might be pushing the weight too high)
