Problemi stampa - non inizia la stampa February 27, 2014 06:53PM |
Re: Problemi stampa - non inizia la stampa February 27, 2014 07:15PM |
G21 ; set units to millimeters G90 ; use absolute coordinates M83 ; use relative distances for extrusion M140 S65; Set bed temperature G1 Z5 F200 ; lift nozzle G1 X2 Y50 F2000; Go to wait for warm position M116; Wait for all temperatures G10 P0 S205 R0 ; Set extruder temperature T0; Select extruder M116; Wait for all temperatures G1 F1800.000 E-1.00000 G1 X83.486 Y74.398 G1 Z0.240 F3600.000
G21 ; set units to millimeters G90 ; use absolute coordinates M83 ; use relative distances for extrusion M140 S65; Set bed temperature G1 Z5 F200 ; lift nozzle G1 X2 Y50 F2000; Go to wait for warm position ;M116; Wait for all temperatures G10 P0 S205 R0 ; Set extruder temperature T0; Select extruder ;M116; Wait for all temperatures G1 F1800.000 E-1.00000 G1 X83.486 Y74.398 G1 Z0.240 F3600.000
Re: Problemi stampa - non inizia la stampa February 28, 2014 04:02AM |
Re: Problemi stampa - non inizia la stampa February 28, 2014 04:58AM |
Re: Problemi stampa - non inizia la stampa February 28, 2014 06:25AM |
Re: Problemi stampa - non inizia la stampa February 28, 2014 07:53AM |
Re: Problemi stampa - non inizia la stampa February 28, 2014 08:05AM |
Re: Problemi stampa - non inizia la stampa March 04, 2014 08:32AM |
Re: Problemi stampa - non inizia la stampa March 04, 2014 08:35AM |
Re: Problemi stampa - non inizia la stampa March 04, 2014 10:01AM |
simosartori76
Good morning, I'm looking for the optimal solution that enables the bonding of the filament to the plan.
I set the temperature of the extruder and the plan as indicated (I also tried to increase / decrease the temperature of the heated surface and the same for the extruder.
I have redone several times to align the height of the Z axis with different values: + near, - near, very near, and now with G31 Z1.8 P658.
Re: Problemi stampa - non inizia la stampa March 04, 2014 11:48AM |
Re: Problemi stampa - non inizia la stampa March 05, 2014 01:03AM |
Re: Problemi stampa - non inizia la stampa March 05, 2014 01:34AM |
Re: Problemi stampa - non inizia la stampa March 05, 2014 01:19PM |
Re: Problemi stampa - non inizia la stampa March 05, 2014 02:16PM |
Re: Problemi stampa - non inizia la stampa March 07, 2014 01:05AM |
Re: Problemi stampa - stampa incompleta March 07, 2014 01:10AM |
Re: Problemi stampa - stampa incompleta March 07, 2014 03:51AM |
simosartori76
Traslate (I'm sorry for the mistakes, automatic web traslate)
Googmorning, I have another problem: the print is incomplete because of a bad extrusion; I also noticed that the first layer, the extruder Rewinds the filament group, passes over the press without filament (I think to flatten it), and when it resumed printing the filament is not present, therefore do not stratify. How can I solve the problem? Thanks and good day to all
Re: Problemi stampa - stampa incompleta March 07, 2014 04:02AM |
Re: Problemi stampa - stampa incompleta March 07, 2014 04:53AM |
