Help please, still setting up, not getting far.. March 01, 2014 01:06PM |
Re: Help please, still setting up, not getting far.. March 01, 2014 01:28PM |
G21 ; set units to millimeters G90 ; use absolute coordinates M83 ; use relative distances for extrusion M140 S65; Set bed temperature G28 ; Home all axes G1 Z5 F200 ; lift nozzle G1 X2 Y50 F2000; Go to wait for warm position M116; Wait for all temperatures G10 P0 S205 R0 ; Set extruder temperature T0; Select extruder M116; Wait for all temperatures
Re: Help please, still setting up, not getting far.. March 01, 2014 01:30PM |
Re: Help please, still setting up, not getting far.. March 01, 2014 01:33PM |
Davek0974
When I home my x axis it seems to park the head off the edge of the bed by about 5-6mm???
The y home seems to park the nozzle right on the edge of the glass plate so that's not right either, I don't think.
Re: Help please, still setting up, not getting far.. March 01, 2014 01:39PM |
Davek0974
The bed and head were fully up to temp before I loaded the g-code, is that not the right way, should I have left them cold and then loaded the file??
Re: Help please, still setting up, not getting far.. March 01, 2014 02:05PM |
Re: Help please, still setting up, not getting far.. March 01, 2014 02:26PM |
Davek0974
... issued a g92 z0 command but the get pos return was not zero for z, it read 0.115 or thereabouts, it would not zero.?
Davek0974
I run the code and it was indeed the M116 waiting that I saw so that's ok, it warmed the bed, then warmed the head, then started printing but it was printing about 3mm above the bed, just spitting out a long filament of PLA.
I paused then reset and used get pos which reported the z axis as being 0.24mm as per code I believe for first layer.
So something I have done is upsetting the z axis, trouble is, I don't know what, I was simply trying to follow the guide.
Any ideas?
Re: Help please, still setting up, not getting far.. March 01, 2014 03:09PM |
Re: Help please, still setting up, not getting far.. March 01, 2014 04:03PM |
Re: Help please, still setting up, not getting far.. March 01, 2014 04:58PM |
Re: Help please, still setting up, not getting far.. March 01, 2014 05:56PM |
Davek0974
Levelling or compensation I guess??
Re: Help please, still setting up, not getting far.. March 01, 2014 06:09PM |
Davek0974
Davek0974
Can someone identify what is going wrong here please, I've spent five hours today just winding the z axis up and down, making notes of readings and generally not getting far.
Re: Help please, still setting up, not getting far.. March 01, 2014 06:49PM |
Re: Help please, still setting up, not getting far.. March 02, 2014 03:35AM |
Re: Help please, still setting up, not getting far.. March 02, 2014 03:42AM |
Re: Help please, still setting up, not getting far.. March 02, 2014 04:50AM |
Re: Help please, still setting up, not getting far.. March 02, 2014 09:18AM |
Davek0974
I think this is the correct startup???
Zero the z axis,
Home x and y,
Run setbed.g,
Load the file (after commenting out any G28 code),
Print from the SD card.
Re: Help please, still setting up, not getting far.. March 02, 2014 11:17AM |
Re: Help please, still setting up, not getting far.. March 03, 2014 09:13AM |
