Re: Replacement Alu bed for those of us with no tools and/or time and/or confidence March 09, 2014 07:17PM |
Re: Replacement Alu bed for those of us with no tools and/or time and/or confidence March 09, 2014 07:57PM |
Re: Replacement Alu bed for those of us with no tools and/or time and/or confidence March 09, 2014 11:58PM |
Re: Replacement Alu bed for those of us with no tools and/or time and/or confidence March 10, 2014 04:09AM |
Re: Replacement Alu bed for those of us with no tools and/or time and/or confidence March 10, 2014 05:08AM |
Re: Replacement Alu bed for those of us with no tools and/or time and/or confidence March 10, 2014 05:58AM |
Davek0974
...I also like the spring loaded idea, is this on all three points?...
Re: Replacement Alu bed for those of us with no tools and/or time and/or confidence March 10, 2014 06:08AM |
Re: Replacement Alu bed for those of us with no tools and/or time and/or confidence March 10, 2014 06:13AM |
Re: Replacement Alu bed for those of us with no tools and/or time and/or confidence March 10, 2014 09:06AM |
Re: Replacement Alu bed for those of us with no tools and/or time and/or confidence March 10, 2014 10:18AM |
Re: Replacement Alu bed for those of us with no tools and/or time and/or confidence March 10, 2014 12:34PM |
Re: Replacement Alu bed for those of us with no tools and/or time and/or confidence March 10, 2014 12:45PM |
How about tapping the 3 holes in the aluminium to take M3 bolts? You would probably want a nut on the other side as well to act as a locknut, but the adjustment would be from just one side.Quote
bobtidey
I did use 3 springs when I did this but more so it would be easier to tweak all 3 points if I found that necessary. I agree one could probably use 2 or 1. Ideally it would be nice to have the nut under the bed captured in some way so that tweaks canjust be from one end. Currently I need a spanner underneath. The other part to be careful about is there wasn't much clearance below on the back two so a nut is fine but the bolt can't protrude much.
Re: Replacement Alu bed for those of us with no tools and/or time and/or confidence March 10, 2014 02:23PM |
dmould
bobtidey
Dave
(#106)
Re: Replacement Alu bed for those of us with no tools and/or time and/or confidence March 10, 2014 02:30PM |
Re: Replacement Alu bed for those of us with no tools and/or time and/or confidence March 10, 2014 03:04PM |
epninety
IMHO an M3 thread in 3mm Ali will be fine, but a nut is probably better.
A properly pressed in steel nutsert would be better still.
My bed is 3mm Tufnol and uses springs on all three mounting screws, which are just tapped into the bed. You don't need massive spring rates unless you are going to use a half kilo of PLA on every print.
Also if your bed is stable, you won't be adjusting it as often as you are used to!
Dave
Re: Replacement Alu bed for those of us with no tools and/or time and/or confidence March 10, 2014 04:14PM |
Davek0974
It's an idea discussed earlier, it is possible but the strength of a fine m3 thread in aluminium is very poor and would strip easily. A nut on each side is far superior IMHO.
Re: Replacement Alu bed for those of us with no tools and/or time and/or confidence March 10, 2014 04:17PM |
Re: Replacement Alu bed for those of us with no tools and/or time and/or confidence March 10, 2014 04:46PM |
KP
How about rivnuts/nutserts?
Re: Replacement Alu bed for those of us with no tools and/or time and/or confidence March 12, 2014 10:29AM |
Re: Replacement Alu bed for those of us with no tools and/or time and/or confidence March 12, 2014 10:59AM |
Re: Replacement Alu bed for those of us with no tools and/or time and/or confidence March 12, 2014 01:05PM |
Re: Replacement Alu bed for those of us with no tools and/or time and/or confidence March 12, 2014 02:30PM |
Re: Replacement Alu bed for those of us with no tools and/or time and/or confidence March 12, 2014 05:31PM |
bobtidey
Assuming bendability (or lack of it) is one of the major selection criteria then Young's modulus of the material should be the significant factor as the amount of bend for a particular force is inversely linear against the modulus ( Table). MDF as in the supplied design has a typical modulus of 4 GPa in the same region as many 'rigid' plastics. Tufnol depending on grade is significantly better ( 8 - 18 GPa). Aluminium and glass are much stiffer again, both being around 70GPa. At that level a 3mm sheet needs a significant load to bend by a factor that would influence the print. Carbon Fibre reinforced sheet would be great if it was affordable.So overall I think the 3mm new Aluminium triangle is going to be a good choice.
Re: Replacement Alu bed for those of us with no tools and/or time and/or confidence March 13, 2014 08:08AM |
bobtidey
Re: Replacement Alu bed for those of us with no tools and/or time and/or confidence March 14, 2014 07:24AM |
Re: Replacement Alu bed for those of us with no tools and/or time and/or confidence March 14, 2014 10:38AM |
Re: Replacement Alu bed for those of us with no tools and/or time and/or confidence March 14, 2014 12:34PM |
Re: Replacement Alu bed for those of us with no tools and/or time and/or confidence March 15, 2014 11:26AM |
Re: Replacement Alu bed for those of us with no tools and/or time and/or confidence March 16, 2014 05:19AM |
Re: Replacement Alu bed for those of us with no tools and/or time and/or confidence March 16, 2014 05:48PM |
