printing tips please, my print is all bubbly on one side mostly... March 03, 2014 06:42PM |
Re: printing tips please, my print is all bubbly on one side mostly... March 03, 2014 06:50PM |
Re: printing tips please, my print is all bubbly on one side mostly... March 04, 2014 03:48AM |
Re: printing tips please, my print is all bubbly on one side mostly... March 04, 2014 03:56AM |
Re: printing tips please, my print is all bubbly on one side mostly... March 06, 2014 04:17AM |
Re: printing tips please, my print is all bubbly on one side mostly... March 06, 2014 04:47AM |
Re: printing tips please, my print is all bubbly on one side mostly... March 06, 2014 04:58AM |
Re: printing tips please, my print is all bubbly on one side mostly... March 06, 2014 05:08AM |
Re: printing tips please, my print is all bubbly on one side mostly... March 06, 2014 05:47AM |
Re: printing tips please, my print is all bubbly on one side mostly... March 06, 2014 06:55AM |
Re: printing tips please, my print is all bubbly on one side mostly... March 06, 2014 08:01AM |
Re: printing tips please, my print is all bubbly on one side mostly... March 06, 2014 08:30AM |
Re: printing tips please, my print is all bubbly on one side mostly... March 07, 2014 05:25AM |
Re: printing tips please, my print is all bubbly on one side mostly... March 07, 2014 05:35AM |
Re: printing tips please, my print is all bubbly on one side mostly... March 07, 2014 06:02AM |
Re: printing tips please, my print is all bubbly on one side mostly... March 07, 2014 06:12AM |
Re: printing tips please, my print is all bubbly on one side mostly... March 07, 2014 06:19AM |
Re: printing tips please, my print is all bubbly on one side mostly... March 07, 2014 06:41AM |
Re: printing tips please, my print is all bubbly on one side mostly... March 07, 2014 08:28AM |
88Zombies
DC42;
It is at a slight angle (i think the photo 'P4' exaggerates this angle slightly) but I assumed this was to act as a suspension on the nozzle, just in case it lowered too much on the Z-Axis.
I thought I fixed this yesterday but looking that the photo it looks as though it's fallen out of place again!
I was considering slipping a hacksaw blade along the x-axis as suggested in the 'troubleshooting'.
I will double check this tonight, thank you
Mykey;
Yes I followed this, i took the nozzle mount apart yesterday to amend the nozzle height, so i double checked the extrusion rate again. I extruded 100mm, when i measured i found that 101.5 was extruded. I amended the config file accordingly but still had the issue shown in the images above. thank you
Re: printing tips please, my print is all bubbly on one side mostly... March 07, 2014 09:36AM |
Re: printing tips please, my print is all bubbly on one side mostly... March 07, 2014 09:42AM |
Re: printing tips please, my print is all bubbly on one side mostly... March 07, 2014 09:47AM |
Re: printing tips please, my print is all bubbly on one side mostly... March 07, 2014 09:54AM |
88Zombies
boom, thank you!!! will give this a whirl!!
really appreciate the help
Re: printing tips please, my print is all bubbly on one side mostly... March 07, 2014 08:31PM |
Re: printing tips please, my print is all bubbly on one side mostly... March 07, 2014 09:51PM |
Re: printing tips please, my print is all bubbly on one side mostly... March 08, 2014 05:34PM |
Re: printing tips please, my print is all bubbly on one side mostly... March 09, 2014 08:27AM |
dmould
Just setting the filament extrusion distance is not enough. You should also do the single-wall test to set your extrusion multiplier - slice a simple cube with the settings set to a single perimeter and no infill at all, and stop the print when the sides are high enough to measure their thickness. Look at the G code file with a text editor and see what the wall thickness should be (as stated in the first comment lines of Slic3r's G code, it will probably be 0.5mm). You average the thickness of the 4 sides. My extrusion factor is set to .833, (a 0.5mm wall actually measured 0.6mm, so set to 0.5/0.6) and I think most people have found that the default setting over-extrudes. It needs a different setting for different widths, and I suspect there is a bug in Slic3r. I think setting the cooling fan option is a waste of time because the Ormerod does not have any fan control so I don't think it does anything.
(#106)
Re: printing tips please, my print is all bubbly on one side mostly... March 09, 2014 08:30AM |
Re: printing tips please, my print is all bubbly on one side mostly... March 09, 2014 09:13AM |
Re: printing tips please, my print is all bubbly on one side mostly... March 09, 2014 09:22AM |
rayhicks
I get a 0.5mm width from my 0.5mm nozzle, I'm not sure why you think it isn't possible
Ray
