Slide bearings on Aluminium Extrusion (no smooth bars) March 04, 2014 01:59PM |
Re: Slide bearings on Aluminium Extrusion (no smooth bars) March 04, 2014 03:58PM |
Re: Slide bearings on Aluminium Extrusion (no smooth bars) March 04, 2014 04:59PM |
Re: Slide bearings on Aluminium Extrusion (no smooth bars) March 05, 2014 04:29PM |
Re: Slide bearings on Aluminium Extrusion (no smooth bars) March 06, 2014 04:33AM |
Re: Slide bearings on Aluminium Extrusion (no smooth bars) March 06, 2014 06:16AM |
Re: Slide bearings on Aluminium Extrusion (no smooth bars) March 06, 2014 12:40PM |
Re: Slide bearings on Aluminium Extrusion (no smooth bars) March 06, 2014 12:49PM |
kwikius
Great idea. I assume its much cheaper than the ground rods and linear bearings? Perhaps you should add it to the RepStrap page.
Re: Slide bearings on Aluminium Extrusion (no smooth bars) March 06, 2014 12:59PM |
Thanks teddy,Quote
badman.teddy.edward
Nicely done.
I was contemplating the second Z support - could you be a gentleman and remind me what size the extrusion is (width not length)?
Re: Slide bearings on Aluminium Extrusion (no smooth bars) March 06, 2014 01:03PM |
Ray, I keep trying to track down a supplier of Carbon Fibre heating tape. It's used in lots of 12V and 240V heating applications - like heated seats, gloves etc. There's some on Ebay but it's in the Russion Federation so might as well be on Mars. Anyhow, just thought I'd mention it.Quote
rayhicks
I should be able to do an A4 sized print bed pretty easily in the current frame, when I get round to X and Z I intend using 500mm extrusion there too, but will have to look hard for a heated bed big enough to use that much space.
Re: Slide bearings on Aluminium Extrusion (no smooth bars) March 06, 2014 02:25PM |
Re: Slide bearings on Aluminium Extrusion (no smooth bars) March 06, 2014 03:19PM |
Re: Slide bearings on Aluminium Extrusion (no smooth bars) March 06, 2014 04:02PM |
Re: Slide bearings on Aluminium Extrusion (no smooth bars) March 06, 2014 04:54PM |
Re: Slide bearings on Aluminium Extrusion (no smooth bars) March 06, 2014 05:41PM |
Re: Slide bearings on Aluminium Extrusion (no smooth bars) March 06, 2014 06:02PM |
Re: Slide bearings on Aluminium Extrusion (no smooth bars) March 06, 2014 06:04PM |
Re: Slide bearings on Aluminium Extrusion (no smooth bars) March 07, 2014 03:32AM |
badman.teddy.edward
Downside is there will be an extra control unit to power up before printing. I can't see myself rewriting the pronterface software so it could manage 2 heat beds...and the net is so slow on this boat even searching for whether the duet has enough ins and outs for such a thing is patience testing. I had a look last night and large beds were hard to find.
Re: Slide bearings on Aluminium Extrusion (no smooth bars) March 07, 2014 05:01AM |
Re: Slide bearings on Aluminium Extrusion (no smooth bars) March 07, 2014 06:44AM |
Re: Slide bearings on Aluminium Extrusion (no smooth bars) March 07, 2014 06:54AM |
Re: Slide bearings on Aluminium Extrusion (no smooth bars) March 07, 2014 07:20AM |
Re: Slide bearings on Aluminium Extrusion (no smooth bars) March 07, 2014 07:29AM |
Re: Slide bearings on Aluminium Extrusion (no smooth bars) March 07, 2014 07:40AM |
Mykey
If someone can point me in the direction of where to get the extrusions, sliders etc, I may well start to build one of these monsters!
Re: Slide bearings on Aluminium Extrusion (no smooth bars) March 07, 2014 08:15AM |
rayhicks
Mykey
Hi Mike, I got my extrusion from here [www.aluminium-profile.co.uk]
Re: Slide bearings on Aluminium Extrusion (no smooth bars) March 07, 2014 08:18AM |
Re: Slide bearings on Aluminium Extrusion (no smooth bars) March 07, 2014 09:06AM |
badman.teddy.edward
This is a horrible mock up but oh well (<5minutes - it is bed time) - laugh at will Roughly what I plan to do. May turn it into a box too...shrug.
Mike I am going to put together my parts list tmrw evening.
I am happy to undergo this mod journey with you - unfortunately I won't be able to commence the build until (hopefully) the 17th, or (more likely) the 28th due to work away from home.
Will post when I work out what I am doing with the mosfets - probably make a design so the controller box fits it all- may as well make it so it will take the Duex4 at the same time...
will let you know..
Re: Slide bearings on Aluminium Extrusion (no smooth bars) March 07, 2014 02:42PM |
Radian
The only tweak I'd do would be to add a 68 Ohm resistor in series with the gate of each MOSFET to combat ringing form the inductance of the connecting wire back to EXT_FET
Re: Slide bearings on Aluminium Extrusion (no smooth bars) March 07, 2014 05:04PM |
Re: Slide bearings on Aluminium Extrusion (no smooth bars) March 07, 2014 05:15PM |
